Hi, I also have an heltec lora v3.2 and I want to power the board with a 3.7V Lipo 5000mAh battery. The voltage I am measuring of the battery is 3.9V when fully charged but the board doesn’t give me the right value, every time it gives me 0.00V using this piece of code I found on the forum:
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, RST_OLED);
#define VBAT_PIN 1
#define VBAT_READ_CNTRL_PIN 37 // Heltec GPIO to toggle VBatt read connection …
// Also, take care NOT to have ADC read connection
// in OPEN DRAIN when GPIO goes HIGH
#define ADC_READ_STABILIZE 10 // in ms (delay from GPIO control and ADC connections times)
float readBatLevel() {
  int analogValue = analogRead(VBAT_PIN);
  float voltage = 0.0041 * analogValue;
  return voltage;
  Wire.begin(SDA_OLED, SCL_OLED);
  // turn on vbat read
  pinMode(VBAT_READ_CNTRL_PIN,OUTPUT);
  digitalWrite(VBAT_READ_CNTRL_PIN, LOW);
  // initialize OLED
  delay(100);
  Serial.println("Awake");
  if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("SSD1306 allocation failed"));
for(;;);
  display.clearDisplay();
  display.setTextSize(1);
  display.setTextColor(WHITE);
  display.setCursor(0, 10);
  display.println("hello");
  display.display();
int count = 0;
  display.setCursor(0, 0);
  float v = readBatLevel();
  display.println(String(v) + " Volt");
  display.println(count++);
  display.display();
  delay(500);
Can you help me get this feature working?
