Heltec Lora HF vs LF filter for LoRa
I received a Heltec LoRa board and was wandering about the LF and HF on board path.
if a board has LF not connected (and HF connected with a resistor/jumper/cap) its for 915/868MHz , right?
but if I change this to the LF (and disconnect HF) is it safe to say that it will work without any problem for 433 ?
Just a maker on the PCB to say what the other components that are fitted are tuned for - changing the resistor won’t make any difference, it will still be HF. This is a common way of marking boards with different parameters of components.
thanks for making it clear.
