Hello, I have a problem with a neo 6m v2 gps module which I am trying to connect to a heltec lora+ esp 32 v2 board, however I cannot collect any gps data, the code I am using is the following
#include <TinyGPS++.h>
TinyGPSPlus gps;
void setup()
Serial2.begin(9600, SERIAL_8N1,2,17);
Serial.println(F(“DeviceExample.ino”));
Serial.println(F(“A simple demonstration of TinyGPS++ with an attached GPS module”));
Serial.print(F("Testing TinyGPS++ library v. ")); Serial.println(TinyGPSPlus::libraryVersion());
Serial.println(F(“by Mikal Hart”));
Serial.println();
// This sketch displays information every time a new sentence is correctly encoded.
while (Serial2.available() > 0)
if (gps.encode(Serial2.read()))
displayInfo();
if (millis() > 5000 && gps.charsProcessed() < 10)
Serial.println(F(“No GPS detected: check wiring.”));
while(true);
void displayInfo()
Serial.print(F(“Location: “));
if (gps.location.isValid())
Serial.print(gps.location.lat(), 6);
Serial.print(F(”,”));
Serial.print(gps.location.lng(), 6);
else
Serial.print(F(“INVALID”));
Serial.print(F(" Date/Time: “));
if (gps.date.isValid())
Serial.print(gps.date.month());
Serial.print(F(”/"));
Serial.print(gps.date.day());
Serial.print(F("/"));
Serial.print(gps.date.year());
else
Serial.print(F(" “));
if (gps.time.isValid())
if (gps.time.hour() < 10) Serial.print(F(“0”));
Serial.print(gps.time.hour());
Serial.print(F(”:"));
if (gps.time.minute() < 10) Serial.print(F(“0”));
Serial.print(gps.time.minute());
Serial.print(F(":"));
if (gps.time.second() < 10) Serial.print(F(“0”));
Serial.print(gps.time.second());
Serial.print(F("."));
if (gps.time.centisecond() < 10) Serial.print(F(“0”));
Serial.print(gps.time.centisecond());
else
Serial.println();
I have also made sure that the neo 6m GPS has the correct power and is in a clear place, however I have not been able to connect the GPS.
Thank you very much for your help
