Heltec LoRa - compilation problem
I bought set of two Heltec WiFi LoRa Oled V3. Nightmare - always problems. First problem with I2C now LoRa.
I try to run LoRa Sender from arduino example - no way. Whatever I tried doesn’t work.
Every time
error: ‘HELTEC_BOARD’ was not declared in this scope
Mcu.begin(HELTEC_BOARD,SLOW_CLK_TPYE);
error: ‘SLOW_CLK_TPYE’ was not declared in this scope
Board is Heltec WiFi LoRa 32.
I’m giving up.
Can you help me to solve this problem or should I give up completely.
Thank you
It sounds like you are not using the right software. There are many threads now in these forums discussing the relevant issues. Try starting with the discussion in the following thread and the links it provides:
Thank you. I read this thread - now I give up totally. Why is it so complicated.
For me Heltec screwup this totally - it is not for hobbyists but for programmers.
I regret that I bought this.
Again
Thank you and bye bye Heltec.
