Heltec LoRa 32 V3 mapping pins to espressif esp32v3
Is there anywhere that it is documented which pins on the Heltec LoRa 32 V3 map to the specific pins on the Espressif Esp32S3? It appears that any schematics I can find for the LoRa V3 no longer exist (or the links are broken). I looked at a pin out of the LoRa board for the V3 and it shows that the second pin from the bottom of the right side shows it mapping to GPIO45, but in fact (through trial and error), I found it maps to the Espressif GPIO5. Getting somewhat frustrated.
I have some remote sensors for a monitoring system for a church camp, which I originally built around the Heltec LoRa 32 V2 board, which work find. But, going forward I want to use the V3 board.
Thanks,
Jim Noeth
