HELTEC HRI-485 cuestion
Hello new friends.
I am evaluating the Heltec HRI-4851 (or HRI-4851L) industrial LoRa RS485 device for an industrial monitoring project.
I need to connect two 4-20mA industrial sensors:
  • VEGABAR 28 pressure transmitter (4-20mA output)
  • PT100 temperature transmitter with 4-20mA output
My idea is to use an RS485 analog input module such as the ICP DAS M-7017C (or a similar 4-20mA to Modbus RS485 converter) connected to the HRI-4851/HRI-4851L through RS485.
Questions:
  1. Is the HRI-4851/HRI-4851L able to communicate directly with a Modbus RTU RS485 analog input module such as the M-7017C?
  2. Can the HRI-4851 read the Modbus registers from the M-7017C and transmit those values through LoRa to another Heltec LoRa node?
  3. Is there any example project or documentation showing Modbus RTU polling over RS485 and LoRa transmission?
  4. Which model is recommended for this application: HRI-4851 or HRI-4851L?
  5. Is there any limitation regarding polling speed or number of Modbus registers that can be transmitted over LoRa?
The goal is to build a long-range industrial monitoring system without using PLCs, transmitting pressure and temperature measurements from remote silos.
Thank you.
