Can you power the esp32 heltec v3 lora through a battery using the Ve pins like a normal esp32? or you can only do it through the port for the 3.7v battery that it comes with
Heltec esp32 v3 battery question
The Ve pin is actually a pin that delivers power from the ESP32’s 3V3 to external devices, so output only. It is not an input pin. For powering a V3 device, you can supply power through 3V7 connector, through USB or through 5V pin.
