Hello everyone
I’m testing 2 different frequency bands (433 MHz and 868 MHz) in LoRa in order to compare if one could be better than other in indoors environments, in theory 433 MHz has more penetration depth as it is a shorter wavelength.
At the moment I only have some heltec boards ESP32 LoRa v1 for the 433 MHz band, as I want the test to be as fair as possible I compare in a P2P connection with some heltec boards v2 in the 868 MHz band. All 4 nodes with omni antennas, all about 2 dBm gain (each pair of antenna specific for the corresponding band)
Now here comes the problem, I use the official libraries example code for Arduino (the LoRaReceiver and LoRaSender) and established a P2P connection for each band, always with SF12 and the sender at different tx power values. Everything works as expected for the v1 board, as soon as I increase the the tx power the RSSI improved. But for the v2 board with a tx power of 17 dBm start to lose packets and with 20 dBm only got a few (2 or 3).
The separation between nodes was a couple of rooms away, the signal for 433 and 868 was quite good no less than -103 or -102 (and only a few packets) no losses in 433 and the same in 868 at 14 dBm, so I think that there is something strange in the v2 board when increase the tx power, for 20 dBm apparently not working at all, even with the nodes side by side. In a nutshell is it possible that there is something in the heltec ESP32 LoRa v2 board that affects the reception at 17 or 20 dBm that not happen with the v1 board?
At this point I only get a fair comparative in both bands at 14 dBm of tx, I attach the test results for both bands.
Thanks in advance.
Results
Heltec v2 868
P2P 868Mhz - 2dBm antenna - SF 12 - txPower 14 dBm11:36:17.484 -> Received packet ‘Hello 0’ with RSSI -100
11:36:17.484 -> snr 12.00
11:36:28.460 -> Received packet ‘Hello 1’ with RSSI -100
11:36:28.460 -> snr 12.00
11:36:39.466 -> Received packet ‘Hello 2’ with RSSI -103
11:36:39.466 -> snr 12.25
11:36:50.442 -> Received packet ‘Hello 3’ with RSSI -97
11:36:50.442 -> snr 11.50
11:37:01.449 -> Received packet ‘Hello 4’ with RSSI -96
11:37:01.449 -> snr 12.00
11:37:12.425 -> Received packet ‘Hello 5’ with RSSI -99
11:37:12.425 -> snr 12.75
11:37:23.433 -> Received packet ‘Hello 6’ with RSSI -96
11:37:23.433 -> snr 12.00
11:37:34.440 -> Received packet ‘Hello 7’ with RSSI -102
11:37:34.440 -> snr 12.75
11:37:45.416 -> Received packet ‘Hello 8’ with RSSI -98
11:37:45.416 -> snr 12.25
11:37:56.422 -> Received packet ‘Hello 9’ with RSSI -98
11:37:56.422 -> snr 12.00
11:39:57.356 -> Received packet ‘Hello 20’ with RSSI -102
11:39:57.356 -> snr 11.75
11:40:08.332 -> Received packet ‘Hello 21’ with RSSI -94
11:40:08.332 -> snr 12.75
11:40:19.341 -> Received packet ‘Hello 22’ with RSSI -95
11:40:19.341 -> snr 12.50
11:40:30.315 -> Received packet ‘Hello 23’ with RSSI -100
11:40:30.315 -> snr 12.50
11:40:41.323 -> Received packet ‘Hello 24’ with RSSI -97
11:40:41.323 -> snr 12.25
11:40:52.331 -> Received packet ‘Hello 25’ with RSSI -103
11:40:52.331 -> snr 11.75
11:41:03.306 -> Received packet ‘Hello 26’ with RSSI -105
11:41:03.306 -> snr 12.25
11:41:14.314 -> Received packet ‘Hello 27’ with RSSI -94
11:41:14.314 -> snr 11.50
11:41:47.276 -> Received packet ‘Hello 30’ with RSSI -101
11:41:47.276 -> snr 12.25
11:42:09.262 -> Received packet ‘Hello 32’ with RSSI -98
11:42:09.262 -> snr 12.25
11:42:42.255 -> Received packet ‘Hello 35’ with RSSI -92
11:42:42.255 -> snr 12.00
11:43:15.249 -> Received packet ‘Hello 38’ with RSSI -97
11:43:15.249 -> snr 12.75
11:43:26.227 -> Received packet ‘Hello 39’ with RSSI -92
11:43:26.227 -> snr 11.75
11:43:37.236 -> Received packet ‘Hello 40’ with RSSI -93
11:43:37.236 -> snr 12.25
11:43:48.211 -> Received packet ‘Hello 41’ with RSSI -93
11:43:48.211 -> snr 12.25
11:43:59.219 -> Received packet ‘Hello 42’ with RSSI -93
11:43:59.219 -> snr 12.00
11:44:10.196 -> Received packet ‘Hello 43’ with RSSI -98
11:44:10.196 -> snr 12.00
11:44:32.208 -> Received packet ‘Hello 45’ with RSSI -97
11:44:32.208 -> snr 12.00
11:44:43.180 -> Received packet ‘Hello 46’ with RSSI -98
11:44:43.180 -> snr 12.00
11:44:54.187 -> Received packet ‘Hello 47’ with RSSI -97
11:44:54.187 -> snr 12.00
11:45:05.192 -> Received packet ‘Hello 48’ with RSSI -99
11:45:05.192 -> snr 11.75
11:45:16.166 -> Received packet ‘Hello 49’ with RSSI -93
11:45:16.166 -> snr 12.75
11:45:27.171 -> Received packet ‘Hello 50’ with RSSI -96
11:45:27.171 -> snr 12.50P2P 868Mhz - 2dBm antenna - SF 12 - txPower 17 dBm
11:53:20.179 -> Received packet ‘Hello 1’ with RSSI -96
11:53:20.179 -> snr 12.75
11:53:31.184 -> Received packet ‘Hello 2’ with RSSI -87
11:53:31.184 -> snr 11.75
11:53:42.155 -> Received packet ‘Hello 3’ with RSSI -92
11:53:42.188 -> snr 12.25
11:53:53.163 -> Received packet ‘Hello 4’ with RSSI -93
11:53:53.163 -> snr 11.75
11:54:04.168 -> Received packet ‘Hello 5’ with RSSI -90
11:54:04.168 -> snr 12.50
11:54:15.142 -> Received packet ‘Hello 6’ with RSSI -97
11:54:15.142 -> snr 11.75
11:54:26.147 -> Received packet ‘Hello 7’ with RSSI -94
11:54:26.147 -> snr 12.25
11:54:37.152 -> Received packet ‘Hello 8’ with RSSI -94
11:54:37.152 -> snr 12.50
11:54:48.123 -> Received packet ‘Hello 9’ with RSSI -91
11:54:48.123 -> snr 11.75
11:55:43.115 -> Received packet ‘Hello 14’ with RSSI -94
11:55:43.115 -> snr 12.00
11:55:54.087 -> Received packet ‘Hello 15’ with RSSI -95
11:55:54.087 -> snr 11.75
11:56:38.077 -> Received packet ‘Hello 19’ with RSSI -94
11:56:38.077 -> snr 11.75
11:56:49.050 -> Received packet ‘Hello 20’ with RSSI -95
11:56:49.083 -> snr 11.50
11:57:00.057 -> Received packet ‘Hello 21’ with RSSI -93
11:57:00.057 -> snr 11.75
11:57:11.063 -> Received packet ‘Hello 22’ with RSSI -96
11:57:11.063 -> snr 12.00
11:57:22.037 -> Received packet ‘Hello 23’ with RSSI -89
11:57:22.037 -> snr 12.75
11:57:33.041 -> Received packet ‘Hello 24’ with RSSI -90
11:57:33.041 -> snr 12.25
11:57:44.045 -> Received packet ‘Hello 25’ with RSSI -91
11:57:44.045 -> snr 12.25
11:57:55.017 -> Received packet ‘Hello 26’ with RSSI -95
11:57:55.017 -> snr 12.25
11:58:06.022 -> Received packet ‘Hello 27’ with RSSI -85
11:58:06.022 -> snr 12.25
11:58:17.026 -> Received packet ‘Hello 28’ with RSSI -84
11:58:17.026 -> snr 12.25
11:58:27.997 -> Received packet ‘Hello 29’ with RSSI -84
11:58:28.030 -> snr 13.50
11:58:39.000 -> Received packet ‘Hello 30’ with RSSI -83
11:58:39.000 -> snr 12.25
11:58:50.004 -> Received packet ‘Hello 31’ with RSSI -83
11:58:50.004 -> snr 11.75
11:59:01.007 -> Received packet ‘Hello 32’ with RSSI -83
11:59:01.007 -> snr 12.25
11:59:11.979 -> Received packet ‘Hello 33’ with RSSI -84
11:59:11.979 -> snr 11.75
11:59:22.985 -> Received packet ‘Hello 34’ with RSSI -84
11:59:22.985 -> snr 13.25
11:59:33.959 -> Received packet ‘Hello 35’ with RSSI -83
11:59:33.992 -> snr 12.50
11:59:44.965 -> Received packet ‘Hello 36’ with RSSI -85
11:59:44.965 -> snr 12.25
11:59:55.969 -> Received packet ‘Hello 37’ with RSSI -85
11:59:55.969 -> snr 12.00
12:00:06.944 -> Received packet ‘Hello 38’ with RSSI -85
12:00:06.944 -> snr 11.75
12:00:17.950 -> Received packet ‘Hello 39’ with RSSI -87
12:00:17.950 -> snr 12.25
12:00:28.955 -> Received packet ‘Hello 40’ with RSSI -93
12:00:28.955 -> snr 12.75
12:00:39.930 -> Received packet ‘Hello 41’ with RSSI -96
12:00:39.930 -> snr 12.25
12:00:50.936 -> Received packet ‘Hello 42’ with RSSI -91
12:00:50.936 -> snr 12.00
12:01:01.910 -> Received packet ‘Hello 43’ with RSSI -87
12:01:01.943 -> snr 12.00
12:01:12.915 -> Received packet ‘Hello 44’ with RSSI -88
12:01:12.915 -> snr 12.50
12:01:23.922 -> Received packet ‘Hello 45’ with RSSI -91
12:01:23.922 -> snr 12.25
12:01:34.895 -> Received packet ‘Hello 46’ with RSSI -91
12:01:34.895 -> snr 11.50
12:01:45.901 -> Received packet ‘Hello 47’ with RSSI -88
12:01:45.901 -> snr 12.25
12:01:56.906 -> Received packet ‘Hello 48’ with RSSI -96
12:01:56.906 -> snr 12.25
12:02:07.877 -> Received packet ‘Hello 49’ with RSSI -93
12:02:07.877 -> snr 12.75
12:02:18.882 -> Received packet ‘Hello 50’ with RSSI -96
12:02:18.882 -> snr 12.505 packets lost
P2P 868Mhz - 2dBm antenna - SF 12 - txPower 20 dBm
a lot of packets lost (N/A)Heltec v1 433
P2P 868Mhz - 2dBm antenna - SF 12 - txPower 14 dBm12:21:46.741 -> Received packet ‘Hello 0’ with RSSI -93
12:21:46.741 -> snr 14.75
12:21:57.714 -> Received packet ‘Hello 1’ with RSSI -90
12:21:57.747 -> snr 14.50
12:22:08.720 -> Received packet ‘Hello 2’ with RSSI -92
12:22:08.720 -> snr 14.75
12:22:19.724 -> Received packet ‘Hello 3’ with RSSI -97
12:22:19.724 -> snr 15.00
12:22:30.696 -> Received packet ‘Hello 4’ with RSSI -89
12:22:30.729 -> snr 14.50
12:22:41.699 -> Received packet ‘Hello 5’ with RSSI -89
12:22:41.699 -> snr 14.75
12:22:52.705 -> Received packet ‘Hello 6’ with RSSI -89
12:22:52.705 -> snr 14.75
12:23:03.679 -> Received packet ‘Hello 7’ with RSSI -89
12:23:03.712 -> snr 14.25
12:23:14.684 -> Received packet ‘Hello 8’ with RSSI -90
12:23:14.684 -> snr 14.25
12:23:25.691 -> Received packet ‘Hello 9’ with RSSI -90
12:23:25.691 -> snr 14.25
12:23:36.665 -> Received packet ‘Hello 10’ with RSSI -92
12:23:36.665 -> snr 14.50
12:23:47.670 -> Received packet ‘Hello 11’ with RSSI -90
12:23:47.670 -> snr 14.50
12:23:58.644 -> Received packet ‘Hello 12’ with RSSI -91
12:23:58.677 -> snr 14.25
12:24:09.650 -> Received packet ‘Hello 13’ with RSSI -91
12:24:09.650 -> snr 14.75
12:24:20.656 -> Received packet ‘Hello 14’ with RSSI -94
12:24:20.656 -> snr 13.75
12:24:31.628 -> Received packet ‘Hello 15’ with RSSI -92
12:24:31.661 -> snr 15.25
12:24:42.636 -> Received packet ‘Hello 16’ with RSSI -92
12:24:42.636 -> snr 15.75
12:24:53.639 -> Received packet ‘Hello 17’ with RSSI -94
12:24:53.639 -> snr 14.00
12:25:04.613 -> Received packet ‘Hello 18’ with RSSI -97
12:25:04.613 -> snr 14.75
12:25:15.619 -> Received packet ‘Hello 19’ with RSSI -98
12:25:15.619 -> snr 15.25
12:25:26.625 -> Received packet ‘Hello 20’ with RSSI -94
12:25:26.625 -> snr 15.00
12:25:37.600 -> Received packet ‘Hello 21’ with RSSI -98
12:25:37.600 -> snr 14.50
12:25:48.606 -> Received packet ‘Hello 22’ with RSSI -96
12:25:48.606 -> snr 14.75
12:25:59.579 -> Received packet ‘Hello 23’ with RSSI -98
12:25:59.579 -> snr 14.75
12:26:10.586 -> Received packet ‘Hello 24’ with RSSI -98
12:26:10.586 -> snr 15.00
12:26:21.594 -> Received packet ‘Hello 25’ with RSSI -98
12:26:21.594 -> snr 14.25
12:26:32.568 -> Received packet ‘Hello 26’ with RSSI -96
12:26:32.568 -> snr 15.00
12:26:43.576 -> Received packet ‘Hello 27’ with RSSI -96
12:26:43.576 -> snr 15.00
12:26:54.549 -> Received packet ‘Hello 28’ with RSSI -98
12:26:54.549 -> snr 14.50
12:27:05.555 -> Received packet ‘Hello 29’ with RSSI -102
12:27:05.555 -> snr 15.50
12:27:16.562 -> Received packet ‘Hello 30’ with RSSI -98
12:27:16.562 -> snr 14.75
12:27:27.535 -> Received packet ‘Hello 31’ with RSSI -91
12:27:27.535 -> snr 15.00
12:27:38.542 -> Received packet ‘Hello 32’ with RSSI -94
12:27:38.542 -> snr 14.75
12:27:49.515 -> Received packet ‘Hello 33’ with RSSI -96
12:27:49.515 -> snr 14.25
12:28:00.521 -> Received packet ‘Hello 34’ with RSSI -97
12:28:00.521 -> snr 15.00
12:28:11.527 -> Received packet ‘Hello 35’ with RSSI -97
12:28:11.527 -> snr 14.75
12:28:22.499 -> Received packet ‘Hello 36’ with RSSI -94
12:28:22.499 -> snr 14.50
12:28:33.505 -> Received packet ‘Hello 37’ with RSSI -95
12:28:33.505 -> snr 14.50
12:28:44.510 -> Received packet ‘Hello 38’ with RSSI -97
12:28:44.510 -> snr 15.00
12:28:55.484 -> Received packet ‘Hello 39’ with RSSI -98
12:28:55.484 -> snr 14.75
12:29:06.489 -> Received packet ‘Hello 40’ with RSSI -94
12:29:06.489 -> snr 14.75
12:29:17.463 -> Received packet ‘Hello 41’ with RSSI -93
12:29:17.496 -> snr 14.50
12:29:28.468 -> Received packet ‘Hello 42’ with RSSI -94
12:29:28.468 -> snr 14.50
12:29:39.476 -> Received packet ‘Hello 43’ with RSSI -99
12:29:39.476 -> snr 14.75
12:29:50.450 -> Received packet ‘Hello 44’ with RSSI -96
12:29:50.450 -> snr 14.75
12:30:01.459 -> Received packet ‘Hello 45’ with RSSI -94
12:30:01.459 -> snr 14.25
12:30:12.433 -> Received packet ‘Hello 46’ with RSSI -94
12:30:12.466 -> snr 14.50
12:30:23.440 -> Received packet ‘Hello 47’ with RSSI -97
12:30:23.440 -> snr 14.75
12:30:34.447 -> Received packet ‘Hello 48’ with RSSI -93
12:30:34.447 -> snr 14.75
12:30:45.418 -> Received packet ‘Hello 49’ with RSSI -93
12:30:45.418 -> snr 15.00
12:30:56.424 -> Received packet ‘Hello 50’ with RSSI -98
12:30:56.424 -> snr 14.75P2P 868Mhz - 2dBm antenna - SF 12 - txPower 17 dBm
12:44:00.624 -> Received packet ‘Hello 0’ with RSSI -93
12:44:00.624 -> snr 15.00
12:44:11.598 -> Received packet ‘Hello 1’ with RSSI -91
12:44:11.598 -> snr 15.75
12:44:22.603 -> Received packet ‘Hello 2’ with RSSI -91
12:44:22.603 -> snr 14.25
12:44:33.609 -> Received packet ‘Hello 3’ with RSSI -86
12:44:33.609 -> snr 14.75
12:44:44.584 -> Received packet ‘Hello 4’ with RSSI -86
12:44:44.584 -> snr 14.50
12:44:55.591 -> Received packet ‘Hello 5’ with RSSI -95
12:44:55.591 -> snr 15.25
12:45:06.563 -> Received packet ‘Hello 6’ with RSSI -91
12:45:06.563 -> snr 15.25
12:45:23.040 -> Received packet ‘Hello 0’ with RSSI -87
12:45:23.040 -> snr 14.50
12:45:34.046 -> Received packet ‘Hello 1’ with RSSI -83
12:45:34.046 -> snr 15.25
12:45:45.052 -> Received packet ‘Hello 2’ with RSSI -98
12:45:45.052 -> snr 14.50
12:45:56.024 -> Received packet ‘Hello 3’ with RSSI -90
12:45:56.024 -> snr 14.25
12:46:07.030 -> Received packet ‘Hello 4’ with RSSI -87
12:46:07.030 -> snr 14.25
12:46:18.035 -> Received packet ‘Hello 5’ with RSSI -90
12:46:18.035 -> snr 14.25
12:46:29.007 -> Received packet ‘Hello 6’ with RSSI -87
12:46:29.007 -> snr 13.75
12:46:40.015 -> Received packet ‘Hello 7’ with RSSI -88
12:46:40.015 -> snr 14.25
12:46:50.987 -> Received packet ‘Hello 8’ with RSSI -86
12:46:51.020 -> snr 14.25
12:47:01.993 -> Received packet ‘Hello 9’ with RSSI -84
12:47:01.993 -> snr 13.75
12:47:13.000 -> Received packet ‘Hello 10’ with RSSI -86
12:47:13.000 -> snr 14.25
12:47:23.974 -> Received packet ‘Hello 11’ with RSSI -87
12:47:23.974 -> snr 14.25
12:47:34.981 -> Received packet ‘Hello 12’ with RSSI -87
12:47:34.981 -> snr 14.25
12:47:45.985 -> Received packet ‘Hello 13’ with RSSI -85
12:47:45.985 -> snr 13.75
12:47:56.958 -> Received packet ‘Hello 14’ with RSSI -89
12:47:56.958 -> snr 13.50
12:48:07.966 -> Received packet ‘Hello 15’ with RSSI -87
12:48:07.966 -> snr 13.75
12:48:18.939 -> Received packet ‘Hello 16’ with RSSI -84
12:48:18.939 -> snr 13.25
12:48:29.946 -> Received packet ‘Hello 17’ with RSSI -88
12:48:29.946 -> snr 14.25
12:48:40.951 -> Received packet ‘Hello 18’ with RSSI -86
12:48:40.951 -> snr 14.50
12:48:51.923 -> Received packet ‘Hello 19’ with RSSI -86
12:48:51.923 -> snr 14.25
12:49:02.928 -> Received packet ‘Hello 20’ with RSSI -87
12:49:02.928 -> snr 14.50
12:49:13.933 -> Received packet ‘Hello 21’ with RSSI -87
12:49:13.933 -> snr 13.75
12:49:24.906 -> Received packet ‘Hello 22’ with RSSI -93
12:49:24.906 -> snr 14.75
12:49:35.911 -> Received packet ‘Hello 23’ with RSSI -86
12:49:35.911 -> snr 14.25
12:49:46.884 -> Received packet ‘Hello 24’ with RSSI -91
12:49:46.918 -> snr 15.00
12:49:57.890 -> Received packet ‘Hello 25’ with RSSI -86
12:49:57.890 -> snr 14.75
12:50:08.896 -> Received packet ‘Hello 26’ with RSSI -87
12:50:08.896 -> snr 14.25
12:50:19.869 -> Received packet ‘Hello 27’ with RSSI -85
12:50:19.902 -> snr 14.50
12:50:30.876 -> Received packet ‘Hello 28’ with RSSI -86
12:50:30.876 -> snr 14.25
12:50:41.882 -> Received packet ‘Hello 29’ with RSSI -85
12:50:41.882 -> snr 13.75
12:50:52.856 -> Received packet ‘Hello 30’ with RSSI -85
12:50:52.856 -> snr 14.50
12:51:03.863 -> Received packet ‘Hello 31’ with RSSI -85
12:51:03.863 -> snr 14.50
12:51:14.835 -> Received packet ‘Hello 32’ with RSSI -85
12:51:14.868 -> snr 14.25
12:51:25.840 -> Received packet ‘Hello 33’ with RSSI -86
12:51:25.840 -> snr 14.25
12:51:36.845 -> Received packet ‘Hello 34’ with RSSI -86
12:51:36.845 -> snr 14.75
12:51:47.816 -> Received packet ‘Hello 35’ with RSSI -86
12:51:47.849 -> snr 14.50
12:51:58.821 -> Received packet ‘Hello 36’ with RSSI -87
12:51:58.821 -> snr 14.50
12:52:09.825 -> Received packet ‘Hello 37’ with RSSI -85
12:52:09.825 -> snr 14.50
12:52:20.797 -> Received packet ‘Hello 38’ with RSSI -90
12:52:20.830 -> snr 14.50
12:52:31.802 -> Received packet ‘Hello 39’ with RSSI -87
12:52:31.802 -> snr 15.00
12:52:42.808 -> Received packet ‘Hello 40’ with RSSI -87
12:52:42.808 -> snr 14.25
12:52:53.782 -> Received packet ‘Hello 41’ with RSSI -87
12:52:53.782 -> snr 14.00
12:53:04.787 -> Received packet ‘Hello 42’ with RSSI -91
12:53:04.787 -> snr 14.50
12:53:15.793 -> Received packet ‘Hello 43’ with RSSI -99
12:53:15.793 -> snr 15.25
12:53:26.766 -> Received packet ‘Hello 44’ with RSSI -86
12:53:26.766 -> snr 14.50
12:53:37.770 -> Received packet ‘Hello 45’ with RSSI -86
12:53:37.770 -> snr 14.50
12:53:48.774 -> Received packet ‘Hello 46’ with RSSI -84
12:53:48.774 -> snr 13.75
12:53:59.748 -> Received packet ‘Hello 47’ with RSSI -84
12:53:59.748 -> snr 14.25
12:54:10.754 -> Received packet ‘Hello 48’ with RSSI -84
12:54:10.754 -> snr 13.75
12:54:21.760 -> Received packet ‘Hello 49’ with RSSI -84
12:54:21.760 -> snr 14.25
12:54:32.732 -> Received packet ‘Hello 50’ with RSSI -83
12:54:32.732 -> snr 13.00P2P 868Mhz - 2dBm antenna - SF 12 - txPower 20 dBm
13:01:25.937 -> Received packet ‘Hello 0’ with RSSI -88
13:01:25.970 -> snr 14.75
13:01:36.943 -> Received packet ‘Hello 1’ with RSSI -91
13:01:36.943 -> snr 14.75
13:01:47.948 -> Received packet ‘Hello 2’ with RSSI -88
13:01:47.948 -> snr 14.25
13:01:58.919 -> Received packet ‘Hello 3’ with RSSI -85
13:01:58.953 -> snr 14.50
13:02:09.926 -> Received packet ‘Hello 4’ with RSSI -85
13:02:09.926 -> snr 14.25
13:02:20.931 -> Received packet ‘Hello 5’ with RSSI -86
13:02:20.931 -> snr 14.50
13:02:31.902 -> Received packet ‘Hello 6’ with RSSI -84
13:02:31.902 -> snr 13.75
13:02:42.910 -> Received packet ‘Hello 7’ with RSSI -86
13:02:42.910 -> snr 13.75
13:02:53.916 -> Received packet ‘Hello 8’ with RSSI -86
13:02:53.916 -> snr 14.25
13:03:04.888 -> Received packet ‘Hello 9’ with RSSI -86
13:03:04.888 -> snr 14.50
13:05:05.835 -> Received packet ‘Hello 20’ with RSSI -85
13:05:05.835 -> snr 14.00
13:05:16.807 -> Received packet ‘Hello 21’ with RSSI -86
13:05:16.807 -> snr 14.50
13:05:27.812 -> Received packet ‘Hello 22’ with RSSI -86
13:05:27.812 -> snr 14.25
13:05:38.817 -> Received packet ‘Hello 23’ with RSSI -86
13:05:38.817 -> snr 14.25
13:05:49.789 -> Received packet ‘Hello 24’ with RSSI -86
13:05:49.789 -> snr 14.50
13:06:00.797 -> Received packet ‘Hello 25’ with RSSI -87
13:06:00.797 -> snr 13.75
13:06:11.802 -> Received packet ‘Hello 26’ with RSSI -87
13:06:11.802 -> snr 14.25
13:06:22.774 -> Received packet ‘Hello 27’ with RSSI -87
13:06:22.774 -> snr 14.75
13:06:33.782 -> Received packet ‘Hello 28’ with RSSI -87
13:06:33.782 -> snr 14.50
13:06:44.755 -> Received packet ‘Hello 29’ with RSSI -85
13:06:44.788 -> snr 14.50
13:06:55.763 -> Received packet ‘Hello 30’ with RSSI -88
13:06:55.763 -> snr 13.75
13:07:06.769 -> Received packet ‘Hello 31’ with RSSI -88
13:07:06.769 -> snr 14.25
13:07:17.744 -> Received packet ‘Hello 32’ with RSSI -89
13:07:17.744 -> snr 14.25
13:07:28.749 -> Received packet ‘Hello 33’ with RSSI -89
13:07:28.749 -> snr 14.50
13:07:39.724 -> Received packet ‘Hello 34’ with RSSI -86
13:07:39.757 -> snr 13.00
13:07:50.729 -> Received packet ‘Hello 35’ with RSSI -86
13:07:50.729 -> snr 14.50
13:08:01.734 -> Received packet ‘Hello 36’ with RSSI -85
13:08:01.734 -> snr 14.75
13:08:12.709 -> Received packet ‘Hello 37’ with RSSI -86
13:08:12.709 -> snr 14.75
13:08:23.713 -> Received packet ‘Hello 38’ with RSSI -84
13:08:23.713 -> snr 14.75
13:08:34.718 -> Received packet ‘Hello 39’ with RSSI -86
13:08:34.718 -> snr 13.75
13:08:45.689 -> Received packet ‘Hello 40’ with RSSI -85
13:08:45.689 -> snr 15.25
13:08:56.694 -> Received packet ‘Hello 41’ with RSSI -85
13:08:56.694 -> snr 14.50
13:09:07.699 -> Received packet ‘Hello 42’ with RSSI -85
13:09:07.699 -> snr 14.75
13:09:18.670 -> Received packet ‘Hello 43’ with RSSI -85
13:09:18.670 -> snr 14.75
13:09:29.677 -> Received packet ‘Hello 44’ with RSSI -85
13:09:29.677 -> snr 14.25
13:09:40.683 -> Received packet ‘Hello 45’ with RSSI -84
13:09:40.683 -> snr 14.75
13:09:51.657 -> Received packet ‘Hello 46’ with RSSI -84
13:09:51.657 -> snr 15.00
13:10:02.663 -> Received packet ‘Hello 47’ with RSSI -85
13:10:02.663 -> snr 14.50
13:10:13.634 -> Received packet ‘Hello 48’ with RSSI -85
13:10:13.667 -> snr 14.50
13:10:24.641 -> Received packet ‘Hello 49’ with RSSI -87
13:10:24.641 -> snr 14.50
13:10:35.646 -> Received packet ‘Hello 50’ with RSSI -97
13:10:35.646 -> snr 14.75
