Heltec Cubecell hang when in Device State Send
Hi, Everyone. I have a problem by using the GY-NEO6MV2 Ublox GPS module with the Heltec Cubecell AB02A on Platformio. When the cubecell in case of DEVICE_STATE_SEND it hanged and didn’t send data to my gateway. However, I try to solve this problem by
  1. Write the code from scratch.
  2. Using the TinyGPS library.
  3. Reset the cubecell every sending 60 times.
  4. Config the GPS to send only GPRMC data.
    Thank you
    This is my latest version.
    include “LoRaWan_APP.h”
#include “Arduino.h”
#include “TinyGPS++.h”
#include “SoftSerial.h”
#include <define.h>
softSerial ss(GPIO5, GPIO7);
TinyGPSPlus gps;
uint8_t devEui[] = { 0xDA, 0x98, 0x35, 0x50, 0x39, 0x5E, 0x92, 0xA6 };
uint8_t appKey[] = { 0x06, 0xD3, 0x9A, 0x81, 0xFE, 0x19, 0x38, 0xC1, 0xE7, 0x12, 0x97, 0xBF, 0x83, 0x8F, 0xF5, 0x26 };
uint32_t appTxDutyCycle = 10000 ;
uint8_t appPort = 2;
void speeddivided() {
fulldata = speed ; // 12550
decimal_prt = fulldata % 100 ; // 50
number_prt = (fulldata - decimal_prt) / 100 ; // 125
realData[3] = number_prt ;
realData[4] = decimal_prt ;
void longtitudedivided() {
fulldata = longitude_encoded ; // 100444256
decimal_prt = fulldata % 1000000 ; // 444256
number_prt = (fulldata - decimal_prt) / 1000000 ; // 100
realData[5] = number_prt ;
// decimal first&second digit
realData[6] = int(decimal_prt / 10000) ; // 44
// decimal third&fourth digit
realData[7] = ((decimal_prt - (realData[6] * 10000)) / 100) ; // 42
// decimal fifth&sixth digit
realData[8] = decimal_prt % 100 ; // 56
void latitudedivided() {
fulldata = latitude_encoded ;
decimal_prt = fulldata % 1000000 ; // 11|11|11
number_prt = (fulldata - decimal_prt) / 1000000 ; // 16
realData[9] = number_prt ;
realData[10] = int(decimal_prt / 10000) ; // 11
realData[11] = ((decimal_prt - (realData[10] * 10000)) / 100) ; // 11
realData[12] = decimal_prt % 100 ; // 11
void PrepareDataForSending() { //must be transform index 3, 4, 5
realData[0] = new_hour ;
realData[1] = new_min ;
realData[2] = new_sec ;
speeddivided() ;
longtitudedivided() ;
latitudedivided() ;
void time(int hour, int min, int sec) {
time_hour_THAI = hour + UTC_TH ;
if (time_hour_THAI > 24) {
new_hour = (time_hour_THAI - 24) + 1 ;
else {
new_hour = time_hour_THAI ;
new_min = min ;
new_sec = sec ;
appDataSize = 13 ;
for (int k = 0 ; k < appDataSize ; k ++) {
    appData[k] = realData[k] ;
Serial.begin(9600);
ss.begin(9600) ;
#if(AT_SUPPORT)
enableAt();
LoRaWAN.ifskipjoin();
int count = 0 ;
/* Code insert */
switch( deviceState )
    case DEVICE_STATE_INIT:
#if(LORAWAN_DEVEUI_AUTO)
#if(AT_SUPPORT)
        getDevParam();
        printDevParam();
        LoRaWAN.setDataRateForNoADR(1);
    case DEVICE_STATE_JOIN:
        LoRaWAN.join();
    case DEVICE_STATE_SEND:
        while (ss.available() > 0) {
            gps.encode(ss.read()) ;
        if (gps.location.isUpdated()) {
            count ++ ;
            longtitude = gps.location.lng() ;
            latitude = gps.location.lat();
            speed = gps.speed.kmph() ;
            time_hour = gps.time.hour() ;
            time_minute = gps.time.minute() ;
            time_second = gps.time.second() ;
            longitude_encoded = (int32_t)(longtitude * 1000000 ); // Scale and round
            latitude_encoded = (int32_t)(latitude * 1000000 );
            speed_encoded = (int32_t)(speed * 100 ); // Scale and round to 2 decimal places
            time(time_hour, time_minute, time_second) ;
            PrepareDataForSending() ;
        if (count > 60) {
            CySoftwareReset() ;
        prepareTxFrame( appPort );
        LoRaWAN.send() ;
    case DEVICE_STATE_CYCLE:
    case DEVICE_STATE_SLEEP:
        lowPowerHandler();
Please pay attention to whether the frequency band and other parameters are correct
I do it correctly. I use AS923_AS1
