Good afternoon. I just bought a Heltec Cube Cell HTCC-AB01, and I would like to know if it is possible to program it as a NODE to communicate with a DRAGINO gateway, using non-LORANWAN (TTN) libraries. I would like to be able to use generic Lora libraries. Would it be possible? Or on the contrary, this micro only accepts a library to connect to LoraWan (TTN)? Thank you very much!. A cordial greeting!
This is possible if the gateway supports it. Or write some gateway receiver programs yourself.
check out the examples below:
