Hi there is a large amount of solder on the case mounting point for thecubecell module, this is causing issues with mounting as the soc does not stay flat on our pcb. This i causing massive headaches for us on our production lines. if someone has a easy remedy for it that would be great!
Heavy solder on case mounting point causing mounting issues on PCB
hi,
We have optimized the welding process of the shielding shell.
Now we are welding from the front.
