Green RGB LED is not working properly
I am using the HTCC AB02 board with the RGB example (RGB.ino). The greed led is turning on and off by chance. Even brightness of the green Led can not be adjusted too. I am using the latest github library. Does anybody found a solution for this problem? This bug makes the RGB LED unusable.
