Hi All
I am using ext0 for waking up Heltec Lora ESP32 board from deepsleep. Works fine if use HIGH pin (GPIO4) for trigger. If i want change it, to LOW pin trigger waking up i use rtc_gpio_pullup_en(GPIO_NUM_4); command, the board keeps wakeup all the time byself. If i put external pullup resistor everythig works fine. If I omit command: rtc_gpio_pullup_en(GPIO_NUM_4); there are not any voltage on pin 4 (pin is isolated btw), if I use command: rtc_gpio_pullup_en(GPIO_NUM_4); there is cca 0.5 V on the pin.
Please help. Is it any other way to put internal pullup or maybe some pins not accepting command?
