Hi folks,
Quite a few of you around here use deepsleep with pin wakeup: most importantly esp_sleep_enable_ext0_wakeup or esp_sleep_enable_ext1_wakeup. As many of you know, by default this increases the power consumption many-fold, with most V3 boards seeing a jump from roughly 20uA to 120uA which is rather painful.
After some digging around today, I have managed to tackle this problem with help from this issue.
A normal sketch to put the VME213 into deepsleep with wakeup from the user-button would look like this:
void deepsleep() {
  esp_sleep_enable_ext0_wakeup((gpio_num_t)21, LOW); // configure pin 21 as wakeup on LOW signal
  esp_deep_sleep_start();                            // start deepsleep
The Arduino-ESP32 package however automatically adds internal pull-up resistors on esp_deep_sleep_start, which are unnecessary as Heltec already integrated these into their design. As such, this should be âblockedâ in your code. The solution looks like this:
void deepsleep() {
  pinMode(21, OUTPUT);
  digitalWrite(21, HIGH);                            // set pin 21 to HIGH manually
  gpio_hold_en((gpio_num_t)21);                      // force pin 21 to stay HIGH
  gpio_deep_sleep_hold_en();                         // force all pins to keep their state during deepsleep
Now enjoy zero additional power consumption during deepsleep!
Note that this applies to all V3 boards, not just the VME213 mentioned in the example!
Edit: refer to comment 8 for a crucial line to make this work in the Heltec_ESP32 framework.
