Getting HTCC-AB02A connected to Helium/TTN
I have two Heltec devices HTCC-AB02A and I can get them talking to each other. I’m interested in connecting these to the Helium Network or TTN but haven’t had any luck with the examples. The two devices I have don’t have the OLED screen if that helps to identify them. I have a Nebra Hotdpot do I also need a Lorawan gateway to connect to TTN and/ Helium?
Thanks in advance,
WW
What examples have you tried? What messages are you seeing on the serial port console?
You have a Nebra Hotspot, is that on the Helium network?
You need to be in range of a Helium network hotspot or a TTN hotspot. Have an account on that network and provision that device on the network.
Thanks for responding dstacer.
The example code is below. It was line 24 that was stopping me from connect to the Helium network which was what I’m interested in using so I haven’t tried TTN once I got on to Helium.
Line 24 was:
I found a document mentioning the following instead and it works:
Yes the Nebra is a Helium Hotspot and it’s on my roof so I knew I was in range I just wasn’t sure if it worked as a gateway or if that was a totally different device requirement. Evidently it works as a gateway too.
Thanks Again.
#include “LoRaWan_APP.h”
#include “Arduino.h”
  • set LoraWan_RGB to Active,the RGB active in loraWan
  • RGB red means sending;
  • RGB purple means joined done;
  • RGB blue means RxWindow1;
  • RGB yellow means RxWindow2;
  • RGB green means received done;
/* OTAA para*/
uint8_t appKey[] = { 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x66, 0x01 };
/* ABP para*/
/OTAA or ABP/
/ADR enable/
/* Application port /
uint8_t appPort = 2;
  • Number of trials to transmit the frame, if the LoRaMAC layer did not
  • receive an acknowledgment. The MAC performs a datarate adaptation,
  • according to the LoRaWAN Specification V1.0.2, chapter 18.4, according
  • to the following table:
  • Transmission nb | Data Rate
  • 1 (first) | DR
  • 2 | DR
  • 3 | max(DR-1,0)
  • 4 | max(DR-1,0)
  • 5 | max(DR-2,0)
  • 6 | max(DR-2,0)
  • 7 | max(DR-3,0)
  • 8 | max(DR-3,0)
  • Note, that if NbTrials is set to 1 or 2, the MAC will not decrease
  • the datarate, in case the LoRaMAC layer did not receive an acknowledgment
appDataSize = 4;
appData[0] = 0x00;
appData[1] = 0x01;
appData[2] = 0x02;
appData[3] = 0x03;
//downlink data handle function example
Serial.printf("+REV DATA:%s,RXSIZE %d,PORT %d\r\n",mcpsIndication->RxSlot?“RXWIN2”:“RXWIN1”,mcpsIndication->BufferSize,mcpsIndication->Port);
Serial.print("+REV DATA:");
for(uint8_t i=0;iBufferSize;i++)
Serial.println();
uint32_t color=mcpsIndication->Buffer[0]<<16|mcpsIndication->Buffer[1]<<8|mcpsIndication->Buffer[2];
#if(LoraWan_RGB==1)
turnOnRGB(color,5000);
turnOffRGB();
#if(AT_SUPPORT)
enableAt();
LoRaWAN.ifskipjoin();
switch( deviceState )
case DEVICE_STATE_INIT:
#if(LORAWAN_DEVEUI_AUTO)
#if(AT_SUPPORT)
getDevParam();
printDevParam();
case DEVICE_STATE_JOIN:
LoRaWAN.join();
case DEVICE_STATE_SEND:
prepareTxFrame( appPort );
LoRaWAN.send();
case DEVICE_STATE_CYCLE:
case DEVICE_STATE_SLEEP:
LoRaWAN.sleep();
