Example LoRaSender_ReadBattery issue
I download the LoRaSender_ReadBattery example program into CubeCell – Dev-Board.
However, it never runs OnTxDone function.
After I checking pingpong example, I found out there has a “Radio.IrqProcess( );” at the end of void loop().
Is it a bug?
  1. The lowPowerHandler(); only run once in this example. The unit didn’t go into sleep mode correctly .
Could Heltec correct these issues and provide a corrected LoRaSender_ReadBattery example with 0.3uA sleep current?
sorry, we can’t find “Radio.IrqProcess( );” Could you git pull?
%E5%9B%BE%E7%89%87
“Radio.IrqProcess( );” is in the “pingpong” example .
Pingpong
The issue in “LoRaSender_ReadBattery” example is the example did not run OnTxDone function.
Sorry, You are correct, It should be 11uA/3.5uA. Please update the example with correct sleep mode power consumption.
it is not a bug, This is a function related to interrupts.
The“ LoRaSender_ReadBattery ” example did not run OnTxDone function…But It should be finished, Right?
%E5%9B%BE%E7%89%87
it called by Radio.IrqProcess( );
Which means LoRaSender_ReadBattery example missing Radio.IrqProcess( );?
If yes, please update the code and add some description.
On the other hand ,could Heltec correct LOWPOWER mode issues and provide a LoRaSender_ReadBattery example with 11uA sleep current?
hi,
“Radio.IrqProcess( );” this function have been called(This is not elicited here). It is not lost.
regarding the 11 uA, it is not a bug. please refer this:%E5%9B%BE%E7%89%87
In LoRaSender_ReadBattery example, how much current (3.3V header powered) when it is running the 2000ms LowPower time?
Hi jasonXu,
I want to get the notes of TX done(OnTxDone function) after the Battery reading sent. Does it mean that I need to add “Radio.IrqProcess( );” in the loop()?
I download the program, connect a 3.7V power supply and 34461A 6 1/2 Digit Multimeter to Vbat port.
The current as show below:
SCREEN_1%5B1%5D
1)TX and LED on:100mA
2)delay(2000); //LowPower time : 10mA
3)Serial.print(“TX Timeout…”); : 6.9mA
It didn’t run in sleep mode.
sorry for up this old topic.
but Im also wonder - do we need use Radio.IrqProcess( ); to fix this issue?
