Hello everyone,
please could someone give me a hint about the correct enviroment for building the example code.
I am experienced in creating projects in CubeIDE/CubeMX, but I can’t get the example code
running on different LoRaNodeNode151’s.
Debugging gives a hint that a duplicating define of MIN/MAX in the LoraMac-part and in the
USB-lib’s from ST’s build enviroment may be a reason for that.
So I suppose that giving the correct version of the CubeIDE & CubeMX for which the example code
was generated for, will be some kind of solution. I tried out different combinations with more or
less no satisfying solution.
At this moment I think about of some kind of ported version especially for the ST’s - from the vanilla
LoRaWAN-code. This would be much easier than repairing examples which are currently not running
at all.
So, some kind of information from HELTEC will be much appreaciated…
Greetings,
Detlef
