Hello! I finally got my Heltec V2 to connect to my gateway on ChirpStack as seen below:
The problem is that it continually rejoins.
I also have this problem where in my serial monitor - I get: DIO1:RX Timeout
LoRaWAN US915_HYBRID Class A start!
joining…
TX on freq 903000000 Hz at DR 4
DIO0:TX Done
RX on freq 923300000 Hz at DR 13
DIO1:RX Timeout
RX on freq 923300000 Hz at DR 8
DIO1:RX Timeout
TX on freq 903100000 Hz at DR 0
DIO0:TX Done
RX on freq 925700000 Hz at DR 10
DIO1:RX Timeout
DIO1:RX Timeout
join failed, rejoin at 30000 ms later
Deep Sleep until Next TxPacket:30000 ms
Is it because I was using the default LoRaWAN file -> OTAA_OLED.ino? (I remember however it would say Sending… when it is reconnectedd)
All help is appreciated! Cheers
