I am using an ESP32 V2 with example software LoRaWanOLED.ino (Library: Heltec_ESP32). Connecting as node to TTN Europe. Settings in the code:
- join method OTAA
- loraWanClass = CLASS_A;
- overTheAirActivation = true;
- loraWanAdr = false;
- appPort = 2;
- confirmedNbTrials = 1;
On “The Things Stack SANDBOX” I see “Successfully processed joint-request” and under “Event Details” : bandwidth: 125khz - spreading factor: 9
I am just 900m away of the public TTN gateway, which is in line of sight.
Is there a possibility to set TX_OUTPUT_POWER to max - LORA_BANDWIDTH to 250 khz - LORA_SPREADING_FACTOR to SF 7 ?
