How can I use the ESP32_LoRaWAN without DeepSleep()? If I use Radio.IrqProcess() and delay() instead of LoRaWAN.sleep(), the loop seems to miss some events like
- DIO0:TX Done
- DIO0:RX Done.
Thanks,
Johannes
Thanks,
Johannes
You can use Class_C mode of LoRaWAN.In this mode, Lora will not sleep.
Made my day
Hi Johannes,
sounds like you got it working, can you share your code or how to do it?
I used the OTAA_OLED example with Class_c and replaced LoRaWAN.sleep() with Radio.IrqProcess() and delay() but it isnt working, i think its still missing events.
Edit: Nevermind my mistake, i never tried it with just setting Class_C. Just setting the class with no other changes works and it does not sleep anymore.
As a feedback for Heltec, i think the LoRaWAN library could use some improvements at this point. Calling sleep when the device should not sleep is a bit misleading and removing the sleep does completely break the LoRa communication which is not what you would expect.
regards
Hi Iodemo,
Just wanted to answer, but you where faster.
I completely agree with you … removing sleep completely breaks the LoRa communication.
