I have some questions about this library. I’m in Brazil, so I’m using the RegionUS915.h config as the frequency is the same as the permitted in here.
1- Is the maximum spreding factor 10? Why? I would like to use 11, or even 12 in some applications. Is a bit confuse the RegionUS915.h file.
Here I have some DR informations, but I dont know which SF and band correspond to each DR.
- Minimal datarate that can be used by the node
#define US915_TX_MIN_DATARATE DR_0/*!
- Maximal datarate that can be used by the node
#define US915_TX_MAX_DATARATE DR_4/*!
#define US915_RX_MIN_DATARATE DR_8/*!
#define US915_RX_MAX_DATARATE DR_13
Looking the line bellow I thin the DR_0 correspond to SF 10, DR_1 to SF 9, DR_2 to SF8 and so on…
static const uint8_t DataratesUS915[] = { 10, 9, 8, 7, 8, 0, 0, 0, 12, 11, 10, 9, 8, 7, 0, 0 };
Am I right?
2 - How the library deal with the DR in order to adjust according appdatasize?
Looking this line below, I guess the max appdatasize I can understand that DR_0 - max data is 28 bytes, DR_1 max data is 53 and so on…
static const uint8_t MaxPayloadOfDatarateUS915[] = { 28, 53, 125, 242, 242, 0, 0, 0, 53, 129, 242, 242, 242, 242, 0, 0 };
However if the ADR is true, and my packet is bigger than 28 bytes, the library can know that the DR canoot be decreased to DR_0?
3 - I think is a stupid question, but I ll do anyway hahah, ADR just work with confirmed messages? I mean if bool loraWanAdr = true; thebool isTxConfirmed = true; must be true?
Thanks!!
