Hello, which pins should I use to be able to use the RTC DS3231 module on ESP32 Lora V2?
ESP32 LoRa V2 and DS3231
I’m using OLED SCL (GPIO15) and OLED SDA (GPIO04) for control and GPIO35 as interrupt input.
YG
Hi, could you show me an example code?
have you made it work?
Regards
I found a solution…
SDA is the GPIO 21 and SCL the 22, and it worked, but after initialize the OLED display with “u8g2.begin()” this GPIO ports change to 15 (SCL) and 4 (SDA).
If after initialize the OLED display connect the I2C modules to 15 and 4, it works.
Other possibility is initialize the Wire library to use 15, 4 GPIO ports (with SoftWire library).
Issue explaining this GPIO port change: https://github.com/Heltec-Aaron-Lee/WiFi_Kit_series/issues/62
Regards
