Hi
I need to measure water pressure from 0 to 1Mpa.
Is there any way to interface SKU SEN0257 Water Pressure Sensor 0 to 5 volt analog output to ESP32 analog input?
Best regards
ESP32 LoRa V2 5 volt ADC input
You can try using a breadboard with a peripheral voltage divider.
Thank you Quency-D
I will try.
