Hello
I have a Wireless Stick Lite (Panda Board) and I use VSCium or Arduino when I run the Wireless Stick Lite factory test code sketch
Serial Monitor
`ets Jun 8 2016 00:22:57
rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 188777542, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:8896
load:0x40080400,len:5828
entry 0x400806ac`
Here is the sketch and the platformio.ini
`[env:heltec_wireless_stick]
platform = espressif32
board = heltec_wireless_stick
framework = arduino
upload_protocol = esptool
upload_port = COM11
monitor_speed = 115200
lib_deps =
Using a library name
Heltec ESP32 Dev-Board
`#include <Arduino.h>
- HelTec Automation™ Wireless Stick Lite factory test code, witch include
- follow functions:
- Node A search WiFi and send WiFi AP number to another node B via LoRa, Node B
- will send a string “abc” back to Node A, if Node A received “abc”, test pass.
- Basic serial port test(in baud rate 115200);
- LED blink test;
- WIFI join and scan test;
- LoRa Ping-Pong test(DIO0 – GPIO26 interrup check the new incoming messages;
- Timer test and some other Arduino basic functions.
*by Aaron.Lee from HelTec AutoMation, ChengDu, China
*成都惠利特自动化科技有限公司
*www.heltec.cn
*this project also realess in GitHub:
*https://github.com/HelTecAutomation/Heltec_ESP32
#include “Arduino.h”
#include “heltec.h”
#include “WiFi.h”
uint64_t chipid;
bool IsACKRecvied = false;
String rssi = “RSSI --”;
String packSize = “–”;
String packet;
unsigned int counter = 0;
void WIFISetUp(void)
//WIFI初始化 + 扫描演示
// Set WiFi to station mode and disconnect from an AP if it was previously connected
WiFi.disconnect(true);
WiFi.mode(WIFI_STA);
WiFi.setAutoConnect(true);
WiFi.begin(“Your WiFi SSID”,“Your Password”);//fill in “Your WiFi SSID”,“Your Password”
delay(100);
byte count = 0;
Serial.print(“Connecting.”);
while(WiFi.status() != WL_CONNECTED && count < 5)
count ++;
Serial.print(".");
delay(500);
if(WiFi.status() == WL_CONNECTED)
Serial.println("\r\nConnecting…OK.");
else
Serial.println(“Connecting…Failed”);
//while(1);
Serial.println(“WIFI Setup done”);
void WIFIScan(unsigned int value)
unsigned int i;
if(WiFi.status() != WL_CONNECTED)
WiFi.mode(WIFI_MODE_NULL);
for(i=0;i<value;i++)
Serial.println(“Scan start…”);
int n = WiFi.scanNetworks();
Serial.println("Scan done");
delay(500);
if (n == 0)
Serial.println("no network found");
//while(1);
else
Serial.print(n);
Serial.println("networks found:");
delay(500);
for (int i = 0; i < n; ++i) {
// Print SSID and RSSI for each network found
Serial.print((i + 1));
Serial.print(":");
Serial.print((String)(WiFi.SSID(i)));
Serial.print(" (");
Serial.print((String)(WiFi.RSSI(i)));
Serial.println(")");;
delay(10);
delay(800);
bool receiveflag = false;
bool resendflag=false;
bool deepsleepflag=false;
void send()
LoRa.beginPacket();
LoRa.print("hello ");
LoRa.print(counter++);
LoRa.endPacket();
Serial.print(“Packet “);
Serial.print(counter-1);
Serial.println(” sent done”);
void onReceive(int packetSize)//LoRa receiver interrupt service
//if (packetSize == 0) return;
packet = “”;
packSize = String(packetSize,DEC);
while (LoRa.available())
packet += (char) LoRa.read();
rssi = "RSSI: " + String(LoRa.packetRssi(), DEC);
receiveflag = true;
void interrupt_GPIO0()
delay(10);
if(digitalRead(0)==0)
if(digitalRead(LED)==LOW)
{resendflag=true;}
else
deepsleepflag=true;
void setup()
pinMode(LED,OUTPUT);
Heltec.begin(true /DisplayEnable Enable/, true /LoRa Disable/, true /Serial Enable/, true /PABOOST Enable/, BAND /**/);
WIFISetUp();
WIFIScan(1);
attachInterrupt(0,interrupt_GPIO0,FALLING);
LoRa.onReceive(onReceive);
send();
LoRa.receive();
if(deepsleepflag)
LoRa.end();
LoRa.sleep();
pinMode(4,INPUT);
pinMode(5,INPUT);
pinMode(14,INPUT);
pinMode(15,INPUT);
pinMode(16,INPUT);
pinMode(17,INPUT);
pinMode(18,INPUT);
pinMode(19,INPUT);
pinMode(26,INPUT);
pinMode(27,INPUT);
digitalWrite(Vext,HIGH);
delay(2);
esp_deep_sleep_start();
if(resendflag)
resendflag=false;
send();
LoRa.receive();
if(receiveflag)
digitalWrite(25,HIGH);
Serial.print("Received Size “);
Serial.print(packSize);
Serial.print(” pakeges: “);
Serial.print(packet);
Serial.print(” With ");
Serial.println(rssi);
send();
LoRa.receive();
Where is the error ??
Thank you
