Error: 'nullptr' was not declared in this scope
I have a code working on my WiFi LoRa 32 (V2) and trying to het it working on my new Cube Cell HTCC-AB02.
To start, I want to use a library to send data over senML. This works with the ESP bud I get a compilation error with the Cube Cell.
Using the example of the library.
// Simple example that prints thingsml to serial output.
#include <thingsml.h>
#define SERIAL_BAUD_RATE 9600
void print(String message) {
    Serial.println(message);
SenMLPack device;
SenMLDoubleRecord temperature(THINGSML_TEMPERATURE);
char buf[100] = {0};
    Serial.begin(SERIAL_BAUD_RATE);
    device.add(temperature);
    temperature.set(21.2);
    device.toJson(buf, 100);
    print(buf);
Error:
In file included from D:\xxxxxxxx\Arduino\libraries\ThingsML\src/thingsml.h:37:0,
                 from D:\xxxxxxxx\Arduino\libraries\ThingsML\examples\arduino\uno\uno_example\uno_example.ino:2:
D:\xxxxxxxx\Arduino\libraries\ThingsML\src/senml/actuator/senml_binary_actuator.h:49:37: error: 'nullptr' was not declared in this scope
     unsigned char * lastAllocated = nullptr;
In file included from D:\xxxxxxxx\Arduino\libraries\ThingsML\src/thingsml.h:43:0,
D:\xxxxxxxx\Arduino\libraries\ThingsML\src/senml/actuator/senml_string_actuator.h:53:28: error: 'nullptr' was not declared in this scope
exit status 1
Fout bij het compileren voor board CubeCell-Board Plus(HTCC-AB02)
Can someone help me?
Use the cubeCell Library and write new code!
Thank you for you’re response.
Witch cubeCell library?
I installed the board and tright some examples form Heltac witch works.
“Nullptr” is a Arduino function and I axially expects that it should work when heltec claim “Perfect Arduino-Compatible!”
Greetings,
Sander
@lansselot. Did you solve this problem? I have the same compilation error with third-party code on CubeCell.
Heltec’s example for the BME280 sensor never worked (with Seeed libraries).
The Adafruit BME280 sensor sketch compiles, uploads and works fine on CubeCell (HTCC-AB02) but ONLY on a Mac Arduino IDE 1.8.13. On a PC the same Arduino IDE throws the ‘nullptr’ error.
See here: https://forum.arduino.cc/t/error-nullptr-was-not-declared-in-this-scope/1045860/3?u=ritrat
No, I still don’t have it working.
So if you can get it to work please let me know.
Same here: cannot upload the same sketch I can upload from a Mac, on Windows. I’m trying also to use the Adafruit BME280 library.
