I make communication with two HTCC-AB01 with AT Command arduino example.
The communication is correct, but when I send a string with 10 characters and later I send other but only with 5 characters, the receiver show me that it has received 10 characters:
Sender side:
+Send String:abcd
TX done
+OK
+Send String:abcd1234
TX done
+OK
+Send String:xyz
TX done
Receiver side:
Received String:abcd
RSSI:-15, SNR:11, Size:4
+OK
Received String:abcd1234
RSSI:-14, SNR:12, Size:8
+OK
Received String:xyzd1234 <-- Error I sent only xyz
RSSI:-15, SNR:13, Size:3
Thanks,
XCO
