Trying to setup a CubeCell Dev Board to work with Dragino LG01-P Single Channel LoRa Gateway. The “LoRa Simple Yun Server” runs on the Gateway and “LoraSender” on the CubeCell.
I can configure most parameters, but I don’t see how to set he SyncWord on the CubeCell?
“LoRa Simple Yun Server”:
float frequency = 868.0;
rf95.setFrequency(frequency);
// Setup Power,dBm
rf95.setTxPower(13);
// Setup Spreading Factor (6 ~ 12)
rf95.setSpreadingFactor(7);
// Setup BandWidth, option: 7800,10400,15600,20800,31200,41700,62500,125000,250000,500000
rf95.setSignalBandwidth(125000);
// Setup Coding Rate:5(4/5),6(4/6),7(4/7),8(4/8)
rf95.setCodingRate4(5);
rf95.setSyncWord(0x34);
“LoraSender”:
// 1: 250 kHz,
// 2: 500 kHz,
// 3: Reserved]
// 2: 4/6,
// 3: 4/7,
// 4: 4/8]
