Downlink (from TTN) is not confirmed by CubeCell AB01
Hello
thank you for the admission in the Heltec-Forum.
I’m using example"LoRaWan" with the “downLinkDataHandle” on the CubeCell AB01 (OTAA, Region EU868, Class A). I recognised, that if I send an downlink via TTN withoud “confirmed” then the data sending works fine. But if I send the donlink with the activated check box for “confirmed” the data is sent repeatedly by TTN. So I assume, that the CubeCell AB01 is not sending correctly the confirmation. Is it a bug in the Heltec-Software or do I need to make a certain configuration for confirmed dowlink to the AB01?
I need the confirmed downlink working correctly.
Kind regards
Äd
Hello dear forists,
anybody out there, who could help me, please?
Let me know, if you need more information to be able to awnser.
Kind regards
Äd
