Hello greetings, I need help… I’m doing tests with a LoRaWan gateway with the CubeCell HTCC-AB01 boards, with the LoRaWan_APP and Cayenne library, connected a DHT22 temperature and humidity sensor, I have doubts about the method of sending the payload of the library cayenneLpp.h that I am using is not the right one, I have made several attempts and the sensor readings are always wrong… with values like:
{relative_humidity_2: 127.5, temperature_1: -0.1}
I share the code, I do not understand how such a well-known DHT22 sensor does not work well with the Lorawan_APP.h library
#include “LoRaWan_APP.h”
#include “Arduino.h”
#include <CayenneLPP.h>
#include “DHT.h”
#define DHTPIN GPIO2
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
/* OTAA para*/
uint8_t devEui[] = { 0x70, 0xB3, 0xD5, 0x7E, 0xD0, 0x05, 0x25, 0x5A };
uint8_t appKey[] = { 0x46, 0x0E, 0xD4, 0x21, 0x0C, 0x65, 0x93, 0xF6, 0x92, 0x04, 0xFD, 0x06, 0x23, 0x85, 0x6C, 0xED };
uint16_t userChannelsMask[6] = { 0xFF00, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000 };
uint8_t appPort = 2;
float temperature = dht.readTemperature();
float humidity = dht.readHumidity();
CayenneLPP lpp(LORAWAN_APP_DATA_MAX_SIZE);
lpp.addTemperature(1, temperature);
lpp.addRelativeHumidity(2, humidity);
appDataSize = lpp.getSize();
memcpy(appData, lpp.getBuffer(), appDataSize);
#if(AT_SUPPORT)
enableAt();
LoRaWAN.ifskipjoin();
dht.begin();
delay(2000);
switch ( deviceState )
case DEVICE_STATE_INIT:
#if(AT_SUPPORT)
getDevParam();
printDevParam();
case DEVICE_STATE_JOIN:
LoRaWAN.join();
case DEVICE_STATE_SEND:
prepareTxFrame( appPort );
LoRaWAN.send();
case DEVICE_STATE_CYCLE:
case DEVICE_STATE_SLEEP:
LoRaWAN.sleep();
