Hi there,
is there a way with the CubeCell board to detect if external USB voltage is connected?
Thanks, Edi
Hi there,
Thanks, Edi
CubeCell board has corresponding power indicator
Well, I want to detect it in software to decide if I can do power intense tasks or not.
all you can do is to read the battery voltage and decide if usb is connected
Oh
. That could take hours. Well, thank you!
In CubeCell, there are corresponding routines for reading battery voltage.
ADC_battery
When the battery is not in use, the voltage read is the output voltage of the charging chip, and the charging chip is powered by the USB, so that you can know whether the USB is connected. But the USB voltage cannot be read directly.
