I am using the HTCC-AB01 (v2) board.
I’m reading DS18B20 values every 3 minutes within the standard arduino LoRa example. Everything works fine but deepsleep current varies every second time (3 µA vs 35 µA). It should be the same every cycle, right?! I am running on battery (V_bat) and the sensor is connected to V_ext.
PowerProfiler readings for some cycles:
This is the code:
#include "LoRaWan_APP.h"
#include "Arduino.h"
#include <Wire.h>
#include <OneWire.h>
* RGB red means sending;
* RGB blue means RxWindow1;
* RGB yellow means RxWindow2;
/* OTAA para*/
uint8_t devEui[] = { XXX };
uint8_t appEui[] = { XXX };
uint8_t appKey[] = { XXX };
/* ABP para*/
uint32_t appTxDutyCycle = 60000*3;
/*OTAA or ABP*/
/*ADR enable*/
/* Application port */
uint8_t appPort = 2;
* to the following table:
* Transmission nb | Data Rate
* 1 (first) | DR
* 2 | DR
* 3 | max(DR-1,0)
* 4 | max(DR-1,0)
* 5 | max(DR-2,0)
* 6 | max(DR-2,0)
* 7 | max(DR-3,0)
* 8 | max(DR-3,0)
OneWire ds(GPIO1); // on pin GPIO1 PIN 6 (a 4.7K resistor is necessary)
pinMode(Vext, OUTPUT);
digitalWrite(Vext, LOW);
byte i;
byte present = 0;
byte type_s;
byte data[9];
byte addr[8];
float celsius, fahrenheit;
if ( !ds.search(addr)) {
Serial.println("No more addresses.");
Serial.println();
ds.reset_search();
delay(250);
return;
Serial.print("ROM =");
for( i = 0; i < 8; i++) {
Serial.write(' ');
Serial.print(addr[i], HEX);
if (OneWire::crc8(addr, 7) != addr[7]) {
Serial.println("CRC is not valid!");
return;
Serial.println();
// the first ROM byte indicates which chip
switch (addr[0]) {
case 0x10:
Serial.println(" Chip = DS18S20"); // or old DS1820
type_s = 1;
case 0x28:
Serial.println(" Chip = DS18B20");
type_s = 0;
case 0x22:
Serial.println(" Chip = DS1822");
type_s = 0;
Serial.println("Device is not a DS18x20 family device.");
return;
ds.reset();
ds.select(addr);
ds.write(0x44, 1); // start conversion, with parasite power on at the end
delay(1000); // maybe 750ms is enough, maybe not
// we might do a ds.depower() here, but the reset will take care of it.
present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
Serial.print(" Data = ");
Serial.print(present, HEX);
Serial.print(" ");
for ( i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
Serial.print(data[i], HEX);
Serial.print(" ");
Serial.print(" CRC=");
Serial.print(OneWire::crc8(data, 8), HEX);
Serial.println();
// Convert the data to actual temperature
// because the result is a 16 bit signed integer, it should
// be stored to an "int16_t" type, which is always 16 bits
// even when compiled on a 32 bit processor.
int16_t raw = (data[1] << 8) | data[0];
if (type_s) {
raw = raw << 3; // 9 bit resolution default
if (data[7] == 0x10) {
// "count remain" gives full 12 bit resolution
raw = (raw & 0xFFF0) + 12 - data[6];
} else {
byte cfg = (data[4] & 0x60);
// at lower res, the low bits are undefined, so let's zero them
if (cfg == 0x00) raw = raw & ~7; // 9 bit resolution, 93.75 ms
else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
//// default is 12 bit resolution, 750 ms conversion time
celsius = (float)raw / 16.0;
Serial.print(" Temperature = ");
Serial.print(celsius);
Serial.print(" Celsius, ");
digitalWrite(Vext, HIGH);
unsigned char *puc;
puc = (unsigned char *)(&celsius);
appDataSize = 6;
appData[0] = puc[0];
appData[1] = puc[1];
appData[2] = puc[2];
appData[3] = puc[3];
appData[4] = (uint8_t)(batteryVoltage>>8);
appData[5] = (uint8_t)batteryVoltage;
Serial.print("Temperature: ");
Serial.print(" C, ");
Serial.print("BatteryVoltage:");
Serial.println(batteryVoltage);
#if(AT_SUPPORT)
enableAt();
LoRaWAN.ifskipjoin();
switch( deviceState )
case DEVICE_STATE_INIT:
#if(LORAWAN_DEVEUI_AUTO)
#if(AT_SUPPORT)
getDevParam();
printDevParam();
case DEVICE_STATE_JOIN:
LoRaWAN.join();
case DEVICE_STATE_SEND:
prepareTxFrame( appPort );
LoRaWAN.send();
case DEVICE_STATE_CYCLE:
case DEVICE_STATE_SLEEP:
LoRaWAN.sleep();
Is there any suggestion, why this happens? Data is sent corretly every time.
Thank you all!
UPDATE 2023-06-08:
Ds.search() was called, so at the first run, the first sensor was found. There was no reset after sending the data, so at the second time, no more addresses were found.
