As in the title, please add temperature readout to the HT-M2808 hotspot dashboard.
If possible of course.
Regards,
Crey
Regards,
Crey
Thank you for your suggestion, we will consider whether to add this feature according to the actual situation.
I agree with this guy! We will need it for sure!
OK, We will add the temperature display in the next update.
Thank you very much
Awesome! And it would be more awesome if Heltec Helium indoor hotspot would have humidity sensor because most of us are placing it outdoors in outdoor enclosures, and humidity is big problem if you want to save your gear and make it work properly. So adding humidity sensor option- would be extraordinary !!!
BUT ANY WAYS, THANKS FOR DASHBOARD AND TEMPERATURE DISPLAY !
cheers !
