What is the purpose of CubeCellelftool?
CubeCellefltool - what is it?
you are speaking about the CubeCellFlash tool?
this tool is needed to write the compiled firmware to the cubecell.
No, I speak about CubeCellelftool.
The compiler output is an elf file.
The tool is needed to build the cyacd file, which is flashed to the cubecell
I have supposed that it is used to generate .cyacd file.
Could you tell me, how should it be used? What is the source file for this tool?
I have not found any information about this tool, that is why I ask.
I dont know the source
But have a look in the platform.txt file for usage.
Thank you very much for answer
Yes, PSoC uses a special firmware format and adds a checksum security function based on the hex file, so a special cyacd format is used. The role of this tool is to convert hex files to cyacd format.
Thank you very much!
