I’ve successfully setup a LoraWan gateway as a port forwarder to TTN. I have also setup a CubeCell with an attached BME 280 sensor and used it to write firmware including necessary keys. TTN is seeing the device BUT I only see “activation” in the data tab. I am not able to find the actual BME280 data anywhere. I’ve loaded the multi sensor decoder up on TTN but I still can’t find the data. I’m sure this is some newbie mistake. Would appreciate someone pointing me in the right direction!
CubeCell WASN Configurator v9.1 TTN where's the data?
As you can see in your first screenshot, ttn did not receive any packet.
In the configurator you can see the log of the cubecell. Please post it here and i can help
I had the exact same issue.
The configurator is able to successfully put firmware on the node and read the sensor. The node is able to join TTN however it will never send a packet for some reason.
Here you go! it’s odd from the log you would think it never is connecting but TTN is seeing it. Thanks.
So by turning off frame counter checks, I am able to see some data. Please see pictures. TTN warns this is not safe to do. Is WASN firmware not creating frames properly? Please advise. Thanks.
Thats a new problem. Your counter is allways 0.
I have hundredS of cubecells in the field without problems.
I will have a look
This morning things are looking better. Frame counter checks are still off. I’ll try turning them back on.
Not sure what happened but everything is working well even with frame check on. Thanks for your support.
