It also happens to me that after a few days the CubeCell node stops transmitting.
I connected sensors via Vext.
The code I use is the following:`
#include “LoRaWan_APP.h”
#include “Arduino.h”
- set LoraWan_RGB to Active,the RGB active in loraWan
- RGB red means sending;
- RGB purple means joined done;
- RGB blue means RxWindow1;
- RGB yellow means RxWindow2;
/* ABP para Cavit_01*/
uint8_t devEui[] = { };;
uint8_t appEui[] = { };;
uint32_t devAddr = ( uint32_t )0x???;
uint8_t appKey[] = { };
uint8_t appSKey[] = { };
uint8_t nwkSKey[] = { };
/OTAA or ABP/
/ADR enable/
/* Application port */
uint8_t appPort = 58;
uint16_t sensor_1 = 0;
uint16_t sensor_2 = 0;
- to the following table:
- Transmission nb | Data Rate
- 1 (first) | DR
- 2 | DR
- 3 | max(DR-1,0)
- 4 | max(DR-1,0)
- 5 | max(DR-2,0)
- 6 | max(DR-2,0)
- 7 | max(DR-3,0)
- 8 | max(DR-3,0)
appDataSize = 9;
// abilito l'alimentazione esterna
Serial.println("Misuro la il valore del sensore analogico");
digitalWrite(Vext,LOW);
delay(40);
///leggo il valore del sensore analogico
sensor_1 = analogRead(ADC2); //return the voltage in mV, max value can be read is 2400mV
//Aspetto un attimo per leggerte il secondo sensore
delay(50);
///leggo il valore del secondo sensore analogico
sensor_2 = analogRead(ADC3); //return the voltage in mV, max value can be read is 2400mV
delay(40);
digitalWrite(Vext,HIGH);
//Serial.print(millis());
Serial.print("Valore della batteria");
uint16_t BatteryVoltage = getBatteryVoltage();
Serial.println(BatteryVoltage);
appData[0] = 0x01;
appData[1] = (uint8_t)(BatteryVoltage >> 8);
appData[2] = (uint8_t)BatteryVoltage;
appData[3] = 0x02;
appData[4] = (uint8_t)(sensor_1 >> 8);
appData[5] = (uint8_t)sensor_1;
appData[6] = 0x03;
appData[7] = (uint8_t)(sensor_2 >> 8);
appData[8] = (uint8_t)sensor_2;
void app(uint8_t port, const uint8_t const data)
// lora_printf(“data:%d\r\n”,data);
switch (port)
case 6:
if (data != 0 )
Serial.println(" ---------- Imposto il nuovo tempo di trasmissione in secondi ---------------- “);
Serial.print(” tempo di trasmissione: “);
int intervallo = (data[0] & 0b11111111) << 8;
intervallo |= (data[1] & 0b11111111);
Serial.print (intervallo);
Serial.println(” secondi");
int tempo = intervallo1000;
delay(200);
Serial.println(tempo);
appTxDutyCycle = tempo;
case 20:
Serial.println(" reset board ");
delay(200);
HW_Reset(0);
Serial.println(" resetted board ");
case 51:
Serial.println(" ---------------- 51 ---------------- ");
Serial.print("data: ");
Serial.println(data[0]);
Serial.println(" ---------------- NN ---------------- ");
//downlink data handle function example
Serial.printf("+REV DATA:%s,RXSIZE %d,PORT %d\r\n",mcpsIndication->RxSlot?“RXWIN2”:“RXWIN1”,mcpsIndication->BufferSize,mcpsIndication->Port);
Serial.print("+REV DATA:");
app(mcpsIndication->Port, mcpsIndication->Buffer);
for(uint8_t i=0;iBufferSize;i++)
Serial.println();
uint32_t color=mcpsIndication->Buffer[0]<<16|mcpsIndication->Buffer[1]<<8|mcpsIndication->Buffer[2];
#if(LoraWan_RGB==1)
turnOnRGB(color,5000);
turnOffRGB();
boardInitMcu();
#if(AT_SUPPORT)
enableAt();
LoRaWAN.ifskipjoin();
//digitalWrite(Vext,LOW);
switch( deviceState )
case DEVICE_STATE_INIT:
#if(AT_SUPPORT)
getDevParam();
printDevParam();
case DEVICE_STATE_JOIN:
LoRaWAN.join();
case DEVICE_STATE_SEND:
prepareTxFrame( appPort );
LoRaWAN.send();
case DEVICE_STATE_CYCLE:
case DEVICE_STATE_SLEEP:
//Serial.print(“I’m going to sleep…”);
LoRaWAN.sleep();
