I used the CubeCell Deep Sleep Mode Wakeup with GPIO program example and added the TX program example , however it is not sleeping after 6 MCU cycles.
Here is the portion of code that caused the issue:
if(lowpower){
lowPowerHandler();
Serial.printf(“woken up - with just this stops at 6 mcu cycles\r\n”);
//delay(10);
//When I add this portion - will not go to sleep after 6 MCU cycles
//txNumber += 0.01;
txNumber += 1;
sprintf(txpacket,"%s",“Hello world number”); //start a package
// sprintf(txpacket+strlen(txpacket),"%d",txNumber); //add to the end of package
DoubleToString(txpacket,txNumber,3); //add to the end of package
turnOnRGB(COLOR_SEND,0); //change rgb color
Serial.printf("\r\nsending packet “%s” , length %d\r\n",txpacket, strlen(txpacket));
