Hi !
I am a beginner with microcontrollers, and wish to make a remote sensor using CubeCell. Collecting and sending temperature (DS, DHT22 sensor), humidity, water level values, that are mostly floating numbers.
I started with the arduino “LoraWanMinimal” example sketch, to understand the work principle.
Joining TTN was OK, example sketch is working sending integer values counting upwards.
I understand this is the send command line, counter is the variable integer value:
LoRaWAN.send(1, &counter, 1, requestack)
How to use this line if I would want to send another variable (f.eg. temperature), that happens to be a float value, like 22,55 ?
Thank you for helping !
Indeed !!!
