Hi Heltec staff,
I would like first to say that the CubeCell EU868 works well.
I do though have some question and potential Issues, that I would like comments on. This will help myself but also for others using the product. I hope this is constructive.
You can use the AT Commands to enter the LoRaWAN keys this work well. But you lose the keys, if you load back the code after a change, this can be very annoying while developing code.
If you want to turn off AT_SUPPORT 0, you cannot load the keys! So the I have had to change the default keys in Commissiong.h , so can turn off the AT support mode. Is there another way to do this?
The Neo Pixel display is on all the time! either connected to USB or via battery only. I have tried to set LoraWan_RGB 0 or 1 but makes no difference. How do you turn off the Neo Pixel display.
How can you control the Tx power Level, to make sure that with an antenna the power level does not exceed the local legal limit. Can you alter it in one of the files if so please give name of file.
The lowest I can get the standby sleep current is either 19.8 µA on USB or 21.6µA on Battery only. This is with AT_Support 0, No Confirm Message, No ADR. How do you get the level to be 3.2 µA? Please advise how you have configured the unit to meet this level.
Many Thanks for your help
Simon Collins
