So it sometimes takes a couple of minutes for the CubeCell to join TTN,
has anyone else seen the same issue ?
I’m basically using the LoRaWan example, but after changing
AT+DevEui=xx8bytes
AT+AppEui=yy8bytes
AT+AppKey=zz16bytes
Device usually does connect, but the variability makes a rapid test cycle harder.
Also it seems the device frequently forgets some of the keys, for testing purposes can you hardcode them in the app, any instructions ?
Would ABP be faster for development ? I tried disabling OTAA (AT+OTAA=0) and configuring the
AT+NwkSKey=xx16bytes
AT+AppSKey=yy16bytes
But the device never joined, so went back to OTAA
