i used a battery of 3,7 with my cubecell but in lowpower the curent give me 4mA
is that right?
Cubecell in lowpower
show how you have it connected? and which cubecell you are talking about?
it might be a short in your connection or your code is leaving pin floating…
mine is connected to a lithium battery that is charged to 4.1v and it draws about 35ua …
btw show your code… it might be your code as well…
#include “Arduino.h”
#include “LoRaWan_APP.h”
- RGB red means sending;
#ifndef LoraWan_RGB
#define LoraWan_RGB 0
// 1: 250 kHz,
// 2: 500 kHz,
// 3: Reserved]
// 2: 4/6,
// 3: 4/7,
// 4: 4/8]
#define RX_TIMEOUT_VALUE 1000
char txpacket[BUFFER_SIZE];
char rxpacket[BUFFER_SIZE];
double txNumber;
int16_t rssi,rxSize;
void DoubleToString( char *str, double double_num,unsigned int len);
#define timetillsleep 1000
#define timetillwakeup 9000
static TimerEvent_t sleep;
static TimerEvent_t wakeUp;
uint8_t lowpower=1;
void onSleep()
Serial.printf(“Going into lowpower mode, %d ms later wake up.\r\n”,timetillwakeup);
lowpower=1;
//timetillwakeup ms later wake up;
TimerSetValue( &wakeUp, timetillwakeup );
TimerStart( &wakeUp );
void onWakeUp()
Serial.printf(“Woke up, %d ms later into lowpower mode.\r\n”,timetillsleep);
lowpower=0;
TimerStart( &sleep );
txNumber=0;
rssi=0;
pinMode(GPIO6 , OUTPUT);
Radio.Init( &RadioEvents );
Radio.Sleep( );
TimerInit( &sleep, onSleep );
onSleep();
if(lowpower){
lowPowerHandler();
txNumber += 0.01;
sprintf(txpacket,"%s",“Hello world number”); //start a package
// sprintf(txpacket+strlen(txpacket),"%d",txNumber); //add to the end of package
DoubleToString(txpacket,txNumber,3); //add to the end of package
turnOnRGB(COLOR_SEND,0); //change rgb color
Serial.printf("\r\nsending packet “%s” , length %d\r\n",txpacket, strlen(txpacket));
- @brief Double To String
- @param str: Array or pointer for storing strings
- @param double_num: Number to be converted
- @param len: Fractional length to keep
@retval None
void DoubleToString( char *str, double double_num,unsigned int len) {
double fractpart, intpart;
fractpart = modf(double_num, &intpart);
fractpart = fractpart * (pow(10,len));
sprintf(str + strlen(str),"%d", (int)(intpart)); //Integer part
sprintf(str + strlen(str), “.%d”, (int)(fractpart)); //Decimal part
Avoid serial communication.
looks like your code sleeps only for few seconds at best… i would recommend reworking your code…
you can also try the lowpower mode by itself and set it to a long period and test.
use a PPKII or a multimeter to measure current while a sleep…
you can also (For testing purposes) use a print statement in the loop to check if the MCU sleeps at all…
Serial.print(".");
it should not print when the lowpower mode is invoked. if it prints then your lowpower mode isn’t working…
Jay.
I have tried print statements to test for sleep.But doing a print while doing lowpower mode , will cause lowpower mode not to complete. I would be interested in knowing how you code this, as I don’t have a meter to test current. And i don’t seem to get more than a few hours battery life when I am awake for 1 minute. transmit twice * 18bytes and sleep for 20 minutes, on a Heltec Solar cubcell .
I use this method to test lowpower has happend. This only works if you are not using the WDT while sleeping : As the watch dog timer will wake every 2 seconds. Loop and increment the TestCounter
case LOWPOWER:
//innerWdtEnable(true);
TestCounter++;
if (TestCounter>5){
turnOnRGB(0x000050,0);// blue flash
delay(250);
turnOnRGB(0,0);
lowPowerHandler();
