In my previous post ( Topic: CubeCell 1/2AA battery problem
CubeCell 1/2AA battery problem), I discovered that the built-in 1/2AA battery socket for HTCC-AB02A can not supply sufficient transient current for the LoRa radio to work properly from a typical lithium chloride 1/2AA battery. If I connect a standard Lithium polymer battery to the battery terminal, then it worked okay.
Heltec does not provide the detailed wiring of power management section of CubeCell board. It is not clear how the battery is connected. The function getBatteryVoltage() from example code also does not seem to provide correct battery voltage.
When I measure the [+] battery terminal, it is connected to the Vdd on the board. The [-] battery terminal is not connected to the GND signal. This seems to be very unusual.
Is there anyway that we can get hold of the detailed schematics of the power management section of CubeCell 1/2AA board? This can help to understand how to wire a Li-Ion battery correctly for this board.
