I am measuring 1.4 mA current draw in sleep mode.
According to the specifications it should be ~ 10 uA
Any ideas on how to reduce the current draw?
Here is the Code:
#include “Arduino.h”
#define INT_GPIO USER_KEY
#define timetillsleep 1000
static TimerEvent_t sleep;
uint8_t lowpower=1;
#include “LoRaWan_APP.h”
- RGB red means sending;
#ifndef LoraWan_RGB
#define LoraWan_RGB 0
#define TX_OUTPUT_POWER 20 // dBm
// 1: 250 kHz,
// 2: 500 kHz,
// 3: Reserved]
#define LORA_SPREADING_FACTOR 10 // [SF7…SF12]
// 2: 4/6,
// 3: 4/7,
// 4: 4/8]
#define RX_TIMEOUT_VALUE 1000
char txpacket[BUFFER_SIZE];
char rxpacket[BUFFER_SIZE];
double txNumber;
int16_t rssi,rxSize;
void DoubleToString( char *str, double double_num,unsigned int len);
void onSleep()
//Serial.printf(“Going into lowpower mode. Press user key to wake up\r\n”);
lowpower=1;
void onWakeUp()
delay(10);
if(digitalRead(INT_GPIO) == 0)
// Serial.printf(“Woke up by GPIO, %d ms later into lowpower mode.\r\n”,timetillsleep);
lowpower=0;
TimerStart( &sleep );
boardInitMcu( );
txNumber=0;
rssi=0;
Radio.Init( &RadioEvents );
//Serial.begin(115200);
pinMode(INT_GPIO,INPUT);
attachInterrupt(INT_GPIO,onWakeUp,FALLING);
TimerInit( &sleep, onSleep );
while(lowpower){
lowPowerHandler();
//Serial.printf(“woken up-with just this stops at 6 mcu cycles\r\n”);
//delay(10);
//txNumber += 0.01;
txNumber += 1;
sprintf(txpacket,"%s",“Hello world number”); //start a package
// sprintf(txpacket+strlen(txpacket),"%d",txNumber); //add to the end of package
DoubleToString(txpacket,txNumber,3); //add to the end of package
//turnOnRGB(COLOR_SEND,0); //change rgb color
//Serial.printf("\r\nsending packet “%s” , length %d\r\n",txpacket, strlen(txpacket));
void DoubleToString( char *str, double double_num,unsigned int len) {
double fractpart, intpart;
fractpart = modf(double_num, &intpart);
fractpart = fractpart * (pow(10,len));
sprintf(str + strlen(str),"%d", (int)(intpart)); //Integer part
sprintf(str + strlen(str), “.%d”, (int)(fractpart)); //Decimal part
