Hola a todos.
Currently I have been using the Cubecell HTCC-AB01, which I am using for a project where I need to transmit data from sensors, the reason why I chose the cubecell was its low consumption, and I have the power profiler kit 2 for which I can Make sure if it consumes little or not, I have been carrying out the corresponding consumption tests using the following sample code:
#include “LoRaWan_APP.h”
#include “Arduino.h”
/* OTAA para*/
uint8_t devEui[] = { };
uint8_t appEui[] = { };
uint8_t appKey[] = {};
/* ABP para*/
uint16_t userChannelsMask[6]={ 0x0000,0x00FF,0x0000,0x0000,0x0000,0x0000 }; //FSB3
//uint16_t userChannelsMask[6]={ 0xFF00,0x00FF,0x0000,0x0000,0x0000,0x0000 }; //FSB2
uint32_t appTxDutyCycle = 1200000;
/OTAA or ABP/
/ADR enable/
/* Application port */
uint8_t appPort = 6;
appDataSize = 4;
appData[0] = 0x00;
appData[1] = 0x01;
appData[2] = 0x02;
appData[3] = 0x03;
//downlink data handle function example
/*void downLinkDataHandle(McpsIndication_t *mcpsIndication)
Serial.printf("+REV DATA:RXSIZE %d,PORT %d\r\n",mcpsIndication->BufferSize,mcpsIndication->Port);
Serial.print("+REV DATA:");
for(uint8_t i=0;iBufferSize;i++)
Serial.println();
#if(AT_SUPPORT)
enableAt();
LoRaWAN.ifskipjoin();
switch( deviceState )
case DEVICE_STATE_INIT:
#if(LORAWAN_DEVEUI_AUTO)
#if(AT_SUPPORT)
getDevParam();
printDevParam();
case DEVICE_STATE_JOIN:
LoRaWAN.join();
case DEVICE_STATE_SEND:
prepareTxFrame( appPort );
LoRaWAN.send();
case DEVICE_STATE_CYCLE:
case DEVICE_STATE_SLEEP:
LoRaWAN.sleep();
And here is the interesting thing, I have 4 rechargeable batteries of 2800mAh of 1.2V each, of which I feed the cubecell by the VIN pin indicated in the datasheet when performing the consumption tests I obtain the following result:
Now the datasheet mentions that when feeding through that pin, the consumption should be around 10uA. Now, after long hours researching and testing, it occurred to me to connect it to the pin where the solar panel should be connected, which would be VS and GND. And to surprise:
The consumption indicates only 10.56uA which is perfect, but when I feed it for that PIn, the cubecell is unable to send a payload to TTN. I am aware that I could try powering it through the 3.3V pin or with a 3.7V lithium battery but I want to use the batteries that I mentioned above. I do not understand what is happening, why there is such a difference in consumption.
