Cubecell HTCC-AB01 + GPS using HTCC-AB02S low power code
Hello guys,
I have already some cubecells HTCC-AB01 version.
I would like to now if I can use the example code provided by you guys to use with HTCC-AB02S in the HTCC-AB01.
LoRaWan_OnBoardGPS_Air530
My plan is just change the code as follow:
GPS.begin();
to something like
GPS.begin(TXpin,RXpin);
//where txpin in this case is pin 15 from cubecell HTCC-AB01 and RXpin is 14
Following this information:
And of course connect an gps module on this RX,TX pins.
Could it be done? I will really apreciate if someone just tell me if is possible or if there is any restriction.
Many thanks!
Hi, have you already tried the example code from Heltec? https://github.com/HelTecAutomation/CubeCell-Arduino/blob/master/libraries/Basics/examples/serial/softwareSerial/TinyGPS/TinyGPS.ino
It works with my AB01 AND Ab02 boards with this softwareSerial definitions:
//softSerial GPSserial(GPIO5 /TX pin -> to GPS-RX/, GPIO6 /RX pin - to GPS-TX/); // AB02
softSerial GPSserial(GPIO2 /TX pin -> to GPS-RX/, GPIO3 /RX pin - to GPS-TX/); // AB01
Hello @Adlerkiez-IoT many thanks, I ll try to adapt this code with lorawan code.
I was not aware of this sofSerial lib! =)
Thanks!
