Is there someone who could help me to understand what I am doing wrong…
With below very simple sketch (with correct OTAA parameters), I apparently can connect to a gateway but the arduino terminal keep saying "“JOIN FAILED! Sleeping for 30 seconds”
Thank you
#include "LoRaWanMinimal_APP.h"
#include "Arduino.h"
//Set these OTAA parameters to match your app/node in TTN
static uint8_t devEui[] = { 0x70, 0xB3, 0xD5, 0x7E, 0xD0, 0x04, 0xB1, 0x15 };
static uint8_t appEui[] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
static uint8_t appKey[] = { 0x41, 0x80, 0x84, 0x98, 0xA6, 0xA6, 0x24, 0xD6, 0xA2, 0x19, 0x73, 0x1F, 0x65, 0x79, 0x30, 0x13 };
static uint8_t counter=0;
//Some utilities for going into low power mode
TimerEvent_t sleepTimer;
//Records whether our sleep/low power timer expired
bool sleepTimerExpired;
static void wakeUp()
sleepTimerExpired=true;
static void lowPowerSleep(uint32_t sleeptime)
sleepTimerExpired=false;
TimerInit( &sleepTimer, &wakeUp );
TimerSetValue( &sleepTimer, sleeptime );
TimerStart( &sleepTimer );
//Low power handler also gets interrupted by other timers
//So wait until our timer had expired
while (!sleepTimerExpired) lowPowerHandler();
TimerStop( &sleepTimer );
if (ACTIVE_REGION==LORAMAC_REGION_AU915) {
//TTN uses sub-band 2 in AU915
LoRaWAN.setSubBand2();
LoRaWAN.begin(LORAWAN_CLASS, ACTIVE_REGION);
//Enable ADR
LoRaWAN.setAdaptiveDR(true);
while (1) {
Serial.print("Joining... ");
LoRaWAN.joinOTAA(appEui, appKey, devEui);
if (!LoRaWAN.isJoined()) {
//In this example we just loop until we're joined, but you could
//also go and start doing other things and try again later
Serial.println("JOIN FAILED! Sleeping for 30 seconds");
lowPowerSleep(30000);
} else {
Serial.println("JOINED");
//Counter is just some dummy data we send for the example
counter++;
//In this demo we use a timer to go into low power mode to kill some time.
//You might be collecting data or doing something more interesting instead.
lowPowerSleep(15000);
//Now send the data. The parameters are "data size, data pointer, port, request ack"
Serial.printf("\nSending packet with counter=%d\n", counter);
//Here we send confirmed packed (ACK requested) only for the first five (remember there is a fair use policy)
bool requestack=counter<50?true:false;
if (LoRaWAN.send(1, &counter, 1, requestack)) {
Serial.println("Send OK");
} else {
Serial.println("Send FAILED");
//Example of handling downlink data
Serial.printf("Received downlink: %s, RXSIZE %d, PORT %d, DATA: ",mcpsIndication->RxSlot?"RXWIN2":"RXWIN1",mcpsIndication->BufferSize,mcpsIndication->Port);
for(uint8_t i=0;i<mcpsIndication->BufferSize;i++) {
Serial.println();
