Hi folks…
I have to connect a MPX5100DP that is working only 5V. What’s the cleanest way to do the job ? a level shifter and a step up ? Or what ? Please advices
CubeCell HTCC-AB01 and device 5V
Some help please ? Tell me what’s the best way … or what’s wrong!
best way is a level shifter of course…
but you would still need to provide a power source for the 5v from somewhere…
maybe the driver below can help, it shows a 3.3v reference so maybe it does work with 3.3v
here is a driver:
Hi, I had the same problem with the SDS011 sensor (5V) and I use a boost converter, see: https://raw.githubusercontent.com/CargoBikoMeter/LoRaWAN-Solar-PM-Sensor/main/images/LoRaWAN-Solar-PM-Sensor.svg
