CubeCell GPS-6502 with CCS811B, HDC1080, MPU9250 and BM180
I have a project were I want to use GPS, movement , temperature, humidity, air quality, barometric pressure and a magnetic reed switch.
The uplinks need to be every 10min with all of the above parameters.
It will be battery (+/- 650mAh) power with a solar for charging. Is the solar panel sufficient (https://heltec.org/product/solar-charging-panel/) for this job?
We have in winter 10 hour sun and at most 2 days cloudy. I am in South Africa https://www.timeanddate.com/sun/@1019933?month=6&year=2021
Can the CubeCell GPS-6502 support four IC2 devices on it’s bus?
Have any one build a project similar to this?
Thanks for any feedback, I will appreciate it.
The standard working voltage of this solar panel is 5.5V, and the standard working current is ≧4mA. The specific voltage and current need to be measured according to the specific light intensity. You can connect 4 sensors to the same set of IIC pins and read their data in turn.
