Hello, I need help,… I am trying to connect a Heltec CubeCell GPS 6502, version 1.1 to LoRa Wan, using the example without changes “LoRaWan_OnBoardGPS:Air530Z” the board was able to connect but then it failed to decode the message in uplink data, the board did not reconnected and I know trying to “JOINNIG”
the board configuration is as follows.
PLACA: CubeCell-GPS (HTCC-AB02S)
LORAWAN_REGION: “REGION_US915”
LORAWAN_CLASS: “CLASS_C”
LORAWAN_DEVEUI: “CUSTOM”
LORAWAN_NETMODE: “OTAA”
LORAWAN_ADR: “ON”
LORAWAN_UPLINKMODE: “CONFIRMED”
LORAWAN_Net_Reservation: “ON”
LORAWAN_AT_SUPPORT: “ON”
LORAWAN_RGB: “ACTIVE”
LoRaWan Debug Level: “Ninguno”
All suggestions are welcome, thank you very much…
