Hi All,
I would like to use a Cubecell dev board to measure temperature using a DS18B20 and send it to TTN via LoRaWan alongside a current battery voltage reading before going into deep sleep for a period of time.
I thought a good starting point for me as a rookie would be to look at the LoRaWan sensor examples provided in Arduino IDE.
The problem is, I’m having difficulty understanding how to construct the payload. Does anybody know where I can find some documentation so that I can understand exactly what is going on in this code? Its not clear to me what a “puc” is.
 * \brief   Prepares the payload of the frame
HDC1080 hdc1080;
    pinMode(Vext,OUTPUT);
    digitalWrite(Vext,LOW);
    hdc1080.begin(0x40);
    float temperature = (float)(hdc1080.readTemperature());
    float humidity = (float)(hdc1080.readHumidity());
    hdc1080.end();
    digitalWrite(Vext,HIGH);
    unsigned char *puc;
    puc = (unsigned char *)(&temperature);
    appDataSize = 10;
    appData[0] = puc[0];
    appData[1] = puc[1];
    appData[2] = puc[2];
    appData[3] = puc[3];
    puc = (unsigned char *)(&humidity);
    appData[4] = puc[0];
    appData[5] = puc[1];
    appData[6] = puc[2];
    appData[7] = puc[3];
    appData[8] = (uint8_t)(batteryVoltage>>8);
    appData[9] = (uint8_t)batteryVoltage;
Given that the DS18B20 is one of the most common sensors that noobs play with, would it be a good idea to provide a commented example for people like me to learn from?
Thanks,
Dan
