I finally got connected my gateway HT-M00 to the TTN server.
For my testing to transmit data from my end node to the server I am just using WASN CUBECELL CONFIGURATOR ver 9.2. In fact I do not have neither work with arduino boards at all, I am planning to use a dsPIC from microchip, that is why I am figuring out how this CUBELCELL->HT-0M00->TTN_SERVER WORKS, so that I can implement it in my dspic code.
Following is the log test of the WASN:
FW-version: 3.1.1
Sensor Port Scanning…
Sensor Bus error
AT Rev 0.8
+LORAWAN=1
+KeepNet=0
+OTAA=1
+Class=A
+ADR=1
+IsTxConfirmed=1
+AppPort=2
+DutyCycle=15000
+ConfirmedNbTrials=4
+ChMask=00000000000000000000FF00
+DevEui=70B3D57ED004E055(For OTAA Mode)
+AppEui=0000000000000000(For OTAA Mode)
+AppKey=80407505C81916D00291C7ADF93147F2(For OTAA Mode)
+NwkSKey=00000000000000000000000000000000(For ABP Mode)
+AppSKey=00000000000000000000000000000000(For ABP Mode)
+DevAddr=00000000(For ABP Mode)
LoRaWAN US915 Class A start!
joining…joined
Probing for GPS …
ASR is Waked,LowPower Mode Stopped
+OK
+Send Hex Data:1234
confirmed uplink sending …
Auto LowPower Mode
+OK
+Send Hex Data:1234
+OK
+Send Hex Data:1234
+OK
+Send Hex Data:1234
Auto LowPower Mode
+OK
+Send Hex Data:5678
Auto LowPower Mode
+OK
+Send Hex Data:5678
Auto LowPower Mode
Following is the corresponding response picture of the TTN
PROBLEMS:
1.) I am not able to receive consecutive set of data, no matter the delay time between the sending. I am just able to receive it only if only after a press the reset button. As you can see I was able to receive only “1234” but not the following data transmitted “5678”
2.) I need the HTCC-AB01 “barebone” C code or example of it so that I can implement it in my dspic. Is there any timing that I must follow between issuing AT+ commands?. If you can please put together header file, fuction for sending or transmitting AT+ commands, etc will be bery nice. As I said I do not use arduino, and every single code you have available is either for Arduino or ESPxx. (C++???)
3.) The following HTCC_AB01 AT comands (V0.6) do not work, it is not reconigsed:
a.- AT+AutoLPM=0 nor 1, it is just always in auto Auto LowPower Mode
b.- AT+LoraSet=? neither fixing a certain value.
Others commands such AT+Copyright=0, AT+ChipID=?, AT+LORAWAN=0 OR 1, and some others are working o.k
If you need me to split these problems into different topics, please just let me know it.
Thank you so much in advance for your time for helping me to resolve my issues.
